pot controlled pwm -- help
Results 1 to 13 of 13
    Jan 2006
    Istanbul
    Cool
    Hi Acetronics,
    PWM filter is not something I created through my output port; it is what picbasic pro recommends.
    If you check the manual or help files, you will find this filter as a solution to scarry pwm out. Still, it is optional.
    If you know something else, pls share it with us so that we can learn. Also, PWM is already an on/off state with different intervals on ON mode, on OFF mode etc. and this is called "modulation".
    Talking The Missing resistor ...
    Hi, sayzer
    As you're asking, it's a pleasure ...
    Just insert a resistor between your Emitter and ground, and the transistor collector current will simply follow linearly ( w. a little offset due to Vbe ...) the PWM value ...
    An U/I converter w/ OpAmp could wipe off this offset, if needed ...
    No, no, don't send flowers ....
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. Serial controlled PWM
    Last Post: - 26th November 2007, 07:47
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
