pot controlled pwm -- help
Results 1 to 13 of 13
    what pic do you use ?
    sample for 16f876:
    TRISA = 255 ' Set PORTA als input
    ADCON1 = 0
    define OSC 8
    DEFINE ADC_BITS 8 ' adc = 8 bits
    v1 var byte 'Variable v1 holds pot information
    high portc.2
    High portd.2 'power indicator
    adcin 0,v1 'Read resistance of pot
    pause 10
    Hpwm 1, v1, 10000 'hardware pwm on RC2
    Angry Pot command
    Hi,DOC
    Forget the POT command ... it gives more headaches than anything Else. @ 4 Mhz only, you can hope for something
    the RC Time command ... ( see manual ) works perfectly for such input readings.
    you'll just have do divide the result by 256.
    Jan 2006
    Quote Originally Posted by maus
    sample for 16f876:
    ADCON1 = 0
    define OSC 8
    high portc.2
    pause 10
    thanks for this code, but doesnt this base itself on the ADCIN producing a number from 0-255 to feed to the hpwm? I have made these changes and the LED's just stay on, even with adjustment of the pot. I dont think the variable output from the adcin is properly formatted for the hpwm
    does anyone know how this is formatted? I cant find any documentation on it.
    Jan 2006
    Default update
    So I gave up on the pot for now and just set a pwm to go to the driver.
    hpwm 1, 127, 5000
    I get 50% duty with a regular LED, but it doesnt work properly with the LED driver
    Jan 2006
    Istanbul
    Cool
    Try the attached PWM filter.
    Play with the driver resistor and the load resistor to catch a nice signal out.
    If you already have a signal amplifier, the NPN transistor may not be necessary.
    Thumbs down ON/OFF vs PWM
    Hi, Sayzer
    PWM is intended to know what you apply to your load, your design is very very very very far from giving a known output ... it's more an ON/OFF output than anything else.
    Sep 2005
    Dayton, Ohio
    I don't really care for the HPWM command. I think it's easier to manually set the registers. This is a conversion from part of my code that may work for you to at least get the PWM working.
    This is for an 8MHz oscillator (on a 18F2525, so double check register names):
    T2CON = 4 'Timer2 = ON; Prescale = 1:1
    PR2 = 200 '(period) this should give you should give you about 10KHz
    CCPR1L = 100 '(duty cycle) 100 should be close to 50%, 20 is about 10%, etc
    To turn PWM ON:
    CCP1CON = 12
    To turn PWM OFF:
    CCP1CON = 0
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Jan 2006
    Istanbul
    Cool
    Hi Acetronics,
    PWM filter is not something I created through my output port; it is what picbasic pro recommends.
    If you check the manual or help files, you will find this filter as a solution to scarry pwm out. Still, it is optional.
    If you know something else, pls share it with us so that we can learn. Also, PWM is already an on/off state with different intervals on ON mode, on OFF mode etc. and this is called "modulation".
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. Serial controlled PWM
    Last Post: - 26th November 2007, 06:47
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
