Pic oscillator?
Results 1 to 6 of 6
Thread: Pic oscillator?
    Qacer's Avatar
    Qacer Guest
    Question Pic oscillator?
    Hey all,
    I was reading the PIC Manual on its internal oscillators and found out that the frequency depends on VDD as well as the external resistor and capacitor. On all of their examples, they are using VDD=5V.
    I was wondering if I can still achieve a 4MHz internal oscillator value if I use a voltage of, say, 3.3V. I'm using a PIC12F675 as my first newbie chip.
    Thanks!
    Qacer, The internal 4 Mhz. oscillator does not use any external capacitor or resistor. The mode you speak of is RCIO or RC. These modes require the external components to for the oscillator. Check the data sheet....
    Qacer's Avatar
    Qacer Guest
    Thanks again, Dave! I'm still immersing myself with the datasheet and PIC manual for midrange microcontrollers.
    Qacer's Avatar
    Qacer Guest
    Question
    By the way, I have another question. I was reading the PIC12F675 data sheet and it states that the following code will calibrate the internal PIC oscillator:
    bsf STATUS, RP0 ;Bank 1
    call 3FFh ;Get the cal value
    movwf OSCCAL ;Calibrate
    bcf STATUS, RP0 ;Bank 0
    Am I doing the right thing using my BASIC coding?
    changed 12F675.inc
    __config _INTRC_OSC_CLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    My next question is: how do I implement the calibration code in BASIC?
    Is this right?
    OSCVAL equ 3FFh ; assign 3FFh to OSCVAL
    call OSCVAL
    OSCCAL = OSCVAL ; ??
    Thanks!
    just a tip
    DEFINE OSCCAL_1K 1
    DEFINE OSCCAL_2K 1
    Qacer's Avatar
    Qacer Guest
    Talking
    Quote Originally Posted by mister_e
    just a tip
    DEFINE OSCCAL_1K 1
    DEFINE OSCCAL_2K 1
    Thanks, mister_e! I knew I saw this somewhere. I started flipping through my manual and found it on page 12. One line is definitely much shorter than a couple.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  3. Replies: 67
    Last Post: - 8th December 2009, 03:27
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
    Last Post: - 12th March 2005, 00:14
