Lvp...
Results 1 to 3 of 3
Thread: Lvp...
    Dec 2005
    Default Lvp...
    Hi all,
    I wanted to know what advantages are gotten programming in LVP mode.
    chip15
    chip15, the advantage of using LVP is that you don't need +12 volts to program the device thru the reset pin. This makes the programing device lower in cost BUT, you lose the availability of the LVP pin designated for the device you are trying to program. This LVP pin can not be used as a general purpose I/O pin. I have seen other quirks with using this mode on diferent PIC processors. I usually just make provisions per the MicroChip documentation for programming the device normally if it does not have bootloader capability. That way I have use of all of the pins for I/O.
    Dec 2005
    Default lvp
    Hi Dave,
    thank you for having answered me. I intend to use LVP with 16f819 and 16f877. These have the way LVP.
    best regards
    chip15
  1. Very Simple ICSP Programmer
    By Squibcakes in forum Schematics
    Last Post: - 1st November 2013, 12:57
  2. LVP will not turn off
    By Garlic in forum General
    Last Post: - 25th February 2010, 12:45
  3. LVP for 18f452
    By Ramonetnet in forum mel PIC BASIC Pro
    Last Post: - 26th April 2008, 02:04
  4. what IS an ICSP connector?
    By mslaney in forum Schematics
    Last Post: - 5th March 2008, 07:05
  5. LCD will not start
