Latched buttons
Results 1 to 10 of 10
Thread: Latched buttons
    Pinckney, Michigan
    I have such a circuit, and can email you a PDF later today. This circuit also handles debouncing, which the other suggestions don't allow time for.
    Feb 2005
    good ideas posted here, never tough of implementing that way, maybe because I never used the On Interrupt instruction before...
    Will try, will tell
    J. Mark: can you attach the PDF to a message, so all ppl see it?
    New England
    If you don't need instant response to the button press, you can get away with not using interrupts.
    Just test the appropriate interrupt flag bit when you want to know if the button was pressed.
    Remeber to clear the bit after checking it.
    Feb 2005
    I just wrote this program to start learning on interrupt, as expected... it didn't work
    @ device pic12F675, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    trisio  =%00110000
    ansel   =%00000000
    cmcon  =%00000111  'Comparators Off
    intcon  =%10001100  'interrupts enable / tmr0 overflow / gpio change interrupt enable
    OPTION_REG = %11010101    ' Set TMR0 configuration
    but1    var gpio.4
    but2    var gpio.5
    led1    var gpio.1
    led2    var gpio.2
    ledwork var gpio.0
    but1st  var bit
    but2st  var bit
    conta   var byte
    on interrupt goto interrupcion
    loop:
    for conta=0 to 255 step 16  'working led rise routine
        pwm ledwork, conta, 10
            disable
            if but1st=1 then
                but1st=0
                high led1
            if but2st=1 then
                but2st=0
                high led2
            enable
    next conta
    high ledwork
    for conta =0 to 100
        pause 10
    next conta
    low led1    'set status buttons leds off
    low led2
    for conta=0 to 255 step 16  'Fall routine
        pwm ledwork, 255-conta, 10
            disable
            if but1st=1 then
                but1st=0
                high led1
            if but2st=1 then
                but2st=0
                high led2
            enable
    next conta
    low ledwork
    low led1   'set button status leds off
    low led2
    goto loop
    disable
    interrupcion:
        but1st=but1
        but2st=but2
        intcon  =%10001101
        resume
    enable
    Any help appreciated
    Pablo
    Feb 2005
    I just changed the previous code so ledwork uses gpio.2 instead of gpio.3 because the payload of the program wasnt functioning properly (no idea why). Now it PWMs the led properly.
    Im still reading the datasheet trying to figure out what I missed for the interrupt part
    Pablo
    Feb 2005
    I fiddled with the intcon/option reg values and it seems to work, at least in the simulation
    please tell me if you see someting blattantly wrong in the code:
    trisio  =%00110000
    ansel   =%00000000
    intcon  =%10101100  'interrupts enable
    OPTION_REG = %11010001    ' Set TMR0 configuration
    but1    var gpio.4
    but2    var gpio.5
    led1    var gpio.1
    led2    var gpio.2
    ledwork var gpio.0
    but1st  var bit
    but2st  var bit
    conta   var byte
    loop:
    ;         disable
            if but1st=1 then
                but1st=0
                high led1
            if but2st=1 then
                but2st=0
                high led2
    ;         enable
    next conta
    high ledwork
    for conta =0 to 100
        pause 10
    next conta
    low led2
    ;         disable
            if but1st=1 then
                but1st=0
                high led1
            if but2st=1 then
                but2st=0
                high led2
    ;         enable
    next conta
    low ledwork
    low led2
    goto loop
    disable
    interrupcion:
        but1st=but1
        but2st=but2
        intcon  =%10001101
        resume
    enable
    Pablo
    Pinckney, Michigan
    The attached PDF file is a circuit similar to one that was published in an old EDN Design Ideas. Originally it used a 74HCT374 and eight switches.
    The advantage is that it latches and debounces the momentary switches. The KYBD_INT signal can be used for interrupting or polling. Once you've read the state of the switches, clear the latch and you're primed for the next keypress.
    I've found it useful in the past, maybe you will to.
  1. In Circut Debug (ICD) buttons palet is disable for 18F2620
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 17th June 2010, 05:21
  2. Button command question
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 08:44
  3. Buttons
    By WarPony in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 01:47
  4. 6 Buttons
    By Johansch in forum General
    Last Post: - 4th July 2007, 15:21
  5. Buttons are driving me nuts
    By Doormatt in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 23:09
