I2C clock frequency?
Results 1 to 9 of 9
    Qacer's Avatar
    Qacer Guest
    Thanks, Dave!
    Coincidentally, I'm trying to figure out the oscillators used in the PIC12F675. I have not quite figured out that part, yet.
    Do I need to define OSC every time I use the I2C routine?
    Thanks again!
    The internal oscillator of the 12F675 run at 4MHZ. if you want to run @29MHZ you must use an external Crystal or a ceramic resonator.
    The DEFINE OSC must be place somewhere on the top of your code and you don't need to write it every time.
    Qacer's Avatar
    Qacer Guest
    Thanks!
    Would serial communication with a 400KHz I2C device still work if my PIC oscillator setting is at 4MHz?
    of course yes, if not we should all use 400KHZ or less as oscillator. PBP generate the right clock frequency for you. Look in the manual in the I2CREAD/I2CWRITE
    Qacer's Avatar
    Qacer Guest
    Question
    By the way, I wanted to use the internal 4MHz oscillator. From what I heard, that the frequency of oscillation might not be as stable. Would I2C communications still work if I go this route?
    Unstable yes and no. At least, i would never trust too much a serial communication RS232 or else running with any internal or ceramic resonator. Worst if the final product maybe use in various ambient temperature.
    For I2C... i never got issue even by running internal OSC... well as now
    Qacer's Avatar
    Qacer Guest
    Talking
    Thanks, mister_e!
    Actually, I just want to use a PIC to communicate to one single I2C device. I won't have any external serial communication via a computer or something similar.
    I wanted to make my circuit very small, so I wanted to get rid of any components that are not too crucial. My main concern is that if I don't use a crystal then I wouldn't be able to communicate accurately with the I2C device.
    But that is good to hear that you haven't had any problems using the internal oscillator with the I2C device.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. I2C function... clock pin?
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2006, 23:09
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
