Can anyone help at getting OWIn & OWOut to work @ 16MHz?
Results 1 to 10 of 10
    Hi jessey,
    Sorry. P18F452.INC is the "Microchip" include file. Open the 18F452.INC file "in your PBP directory". Make the change to this one. Not the one located in your MPLAB directory.
    PBP has a device specific header file for each PIC it supports. These header files contain default config fuse settings for each device.
    This is the file you edit. Not the Microchip header file.
    Yes. You can make changes to over-ride config fuse settings embedded in the final .hex file with your EPIC software, however, it may not always work like you might expect.
    Example. You compile your code using the default config fuse settings in the "18F452.INC" file in your "PBP" directory. You launch the EPIC software from within MCS, and you make changes to the config fuse settings with your EPIC software.
    Now you click program, and it stil uses the default settings from the .hex file.
    What happened? If you have the "Reread file before programming", and "Update Configuration From File" options selected, it just reloads the .hex file "from disc" into memory, and dumps the default settings in.
    What most folks forget is to click the "Save" button after making changes to the config fuse settings to save them back to the .hex file on disc.
    MPASM does not like it when you have config fuse settings in your code & in the PBP 18F452.INC file. You can only have them in "1" location or it returns this error message.
    If you place the config fuse directive in your code, then you need to comment them all out in the PBP 18F452.INC header file.
    Change your Microchip P18F452.INC file back to its original state.
    Look in your "PBP" directory for 18F452.INC. Make only the change I mentioned previously, and see what you get.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    jessey's Avatar
    jessey Guest
    Default I'm sure I'll get it now..........Thanks
    Many Thanks Bruce,
    We seem to be playing tag here but after reading your last post I found the proper .inc file in PBP, thanks for the clarifation. Cool.............
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F452, r = dec, w = -311, f = inhx32
    INCLUDE "P18F452.INC" ; MPASM Header
    __CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    __CONFIG _CONFIG4L, _LVP_OFF_4L
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    And these are the 3 that I couldn't get to compile. It makes perfect sense now. Live and learn!! This list is great............
    Many Thanks Again
    jessey
    jessey's Avatar
    jessey Guest
    Default Everything is working good now, thanks for your help.
    Hello Bruce,
    It worked like a charm. I commented out all 3 lines in the 18F452.INC file in PBP and now have all 11 of the @ __CONFIG fuse settings compiled into my program and have total control over all the settings within the program I'm writing. Now I can just cut and paste them into any future programs. And also, now my pause statements have the correct timing too so everything is working just great. Thanks again!
    jessey
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  2. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
  3. help
    Last Post: - 9th February 2005, 21:42
  4. Need once your help one please
    Last Post: - 9th February 2005, 21:33
  5. can i slowdown owin and owout
    By Eugen in forum mel PIC BASIC Pro
    Last Post: - 29th January 2005, 23:17
