pic16F88 problems
Results 1 to 12 of 12
    sskeet's Avatar
    sskeet Guest
    Quote Originally Posted by Bruce
    If your settings are the same at home, and it is loading & using config word settings in your .hex file, then i would have to suspect something in your circuit since your code posted as-is above works just fine.
    Thanks for the verification...
    What is better to use, INTRC or INTRC (CLockout)? Does it make a diff?
    My circuit is pretty simple, 5v to power, ground is good, and I have a 10k pullup attached to MCLR, although I believe I am disabling it in the header statement anyway??
    What more should/could there be in the circuit?
    With these settings @ DEVICE INTRC_OSC, LVP_OFF, WDT_OFF, MCLR_OFF you won't need much more than power. Assuming these config word settings are actually being programmed into the PIC as expected.
    MCLR_OFF just disables the reset function on the /MCLR pin allowing it to be used for an input VS external reset.
    You might also want to include the decoupling cap as shown in your PBP manual between Vcc and ground. Locate this cap as close to the PIC power pins as possible. Without it you can sometimes waste a ton of time chasing problems. Especially on "A" version PICs. These are more succeptible to noise than older non "A" revs.
    As for clockout VS no clockout, that really depends on you. All this does is output the clock/4 on OSC2. If you want the OSC2 pin for I/O, then obviously you're better off with no clockout.
    If you're curious about what these osc config options are, just look in your data sheet at the Special Features of the CPU section under CONFIGURATION WORD.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    sskeet's Avatar
    sskeet Guest
    Thanks Bruce, great info..I should be able to troubleshoot a little better now...I will report back with what the problem was as soon as I figure it out later...
    sskeet's Avatar
    sskeet Guest
    Smile
    Damn, can I delete this thread? lol
    My 5V regulator on the board was toast...I replaced it and voila
    I really appreciate the responses though!
    **** happens
    Nov 2007
    Question pic16f88 pwm
    hi guys can any one help me with assembly code for dimming an led using the pic16f88.i have read the datasheet and and i have come up with code but it doesnt work.
    can anyone please tell me whats wrong with with this code.
    list p=16f88
    INCLUDE "p16f88.inc"
    _;****Set up the Constants****
    STATUS equ 03h
    TRISA equ 85h
    TRISB equ 86h
    PORTA equ 05h
    PORTB equ 06h
    COUNT2 equ 21h
    COUNT1 equ 20h
    ANSEL equ 9Bh
    OSCCON equ 8Fh
    CCP1CON equ 17h
    T2CON equ 12h
    TMR2 equ 11h
    CCPR1L equ 15h
    PR2 equ 92h
    PIR1 equ 0Ch
    PIE1 equ 8Ch
    movlw B'00000000' ; 8Mhz 4Mhz = B'01100000'31.25khz
    bsf STATUS, 5
    movwf OSCCON
    nop
    nop
    nop
    bcf STATUS, 5
    movlw b'00111100'
    movwf CCP1CON
    bsf 03h,5
    movlw 00h
    movwf TRISA
    movlw 00h
    movwf TRISB
    movlw 00h
    movwf ANSEL
    movlw b'11111111'
    movwf PR2
    bcf 03h,5
    movlw b'00001111'
    movwf TMR2
    Start
    movlw b'00001111'
    movwf CCPR1L
    Loop1
    decfsz CCPR1L
    goto Loop1
    goto Start
  1. Problems with 1-Wire DS2438 and PIC16F88
    By HeadCase in forum mel PIC BASIC Pro
    Last Post: - 4th February 2011, 19:51
  2. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
  3. Replies: 8
    Last Post: - 7th December 2006, 16:42
  4. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 18th September 2006, 00:31
  5. Problems getting started
    By damiko in forum mel PIC BASIC Pro
    Last Post: - 10th July 2005, 16:53
