Help with passcode
Results 1 to 5 of 5
    m0cke's Avatar
    m0cke Guest
    Question Help with passcode
    Hi all,
    I'm currently trying to get a passcode working for a BCD input (i.e. DTMF decoder output)
    I have the BCD Input as follows
    GetDtmf:
    dtmf = 0
    IF DT0 = 1 Then 'Check Input port 0
    dtmf = dtmf + 1
    EndIF
    IF DT1 = 1 Then 'Check Input port 1
    dtmf = dtmf + 2
    EndIF
    IF DT2 = 1 Then 'Check Input port 2
    dtmf = dtmf + 4
    EndIF
    IF DT3 = 1 Then 'Check Input port 3
    dtmf = dtmf + 8
    EndIF
    So each BCD line is added to the VAR dtmf,
    Then further down I have a lookup section of code
    C = C + 1 'Add 1 to Tone Count Register
    LookDown dtmf,["0,4,8,2,3,9,1,7,5,6"],J 'LookDown Table
    IF J = 0 then error
    IF C = 1 AND J = 1 Then Key 'Check Codes are sent in correct order
    IF C = 2 AND J = 2 Then Key
    IF C = 3 AND J = 3 Then Key
    IF C = 4 AND J = 4 Then Key
    IF C = 5 AND J = 5 Then Key
    IF C = 6 AND J = 6 Then Key
    IF C = 7 AND J = 7 Then Key
    IF C = 8 AND J = 8 Then Key
    IF C = 9 AND J = 9 Then Key
    So if I send a 4 on DTMF which will activate DT2 and write 4 to the var dtmf, then the loookup table should see the 4 at position 1 and write a 1 to the var J, problem is it's error out here at the line
    IF J = 0 then error ..
    Any ideas anyone please?
    Jim
    Jim, Here is how I do it for a repeater control link w an 16F628.
    CHECKIN:' GATHER TOUCH TONE DATA FROM RECEIVER
    DVEDGE = 1 'REMEMBER THE LEADING EDGE
    POINTER = PORTA & 15 'PULL IN DATA AND STRIP TO 4 BITS
    REORDER:' REORDER OUTPUT FROM TONE DECODER
    ' ACTUAL KEY= D 1 2 3 4 5 6 7 8 9 0 * # A B C
    lOOKUP POINTER,[$D,$1,$2,$3,$4,$5,$6,$7,$8,$9,$0,$E,$F,$A,$B,$C],POINTER
    IF POINTER = $F THEN EVALKEY 'IF # KEY THEN EVALUATE TONE SEQUENCE
    CCOUNT = CCOUNT + 1 'ADD 1 TO THE CODE COUNTER
    CCOUNT = CCOUNT MIN 9 'LIMIT TOUCH TONE CHARACTERS
    TONES(CCOUNT) = POINTER 'COPY TONE TO ARRAY FOR LATER EVALUATION
    GOTO LOOP
    EVALKEY:' EVALUATE TONE SEQUENCE
    TONE = 0 'CLEAR TONE OUTPUT FLAG
    BADCOD = 1 'SET BADCOD FLAG
    IF CCOUNT > 6 THEN
    FOR SCRATCH1 = 1 TO 4
    CODEWRD = CODEWRD << 4 'MAKE ROOM FOR THE NEW CODE
    CODEWRD = CODEWRD | TONES(SCRATCH1)
    NEXT
    IF CODEWRD = UNLOCK THEN 'IF CORRECT UNLOCK CODE THEN EVALUATE REST OF MESSSAGE
    CODEWRD = 0 'MAKE ROOM FOR THE NEW CODES
    m0cke's Avatar
    m0cke Guest
    Hi Dave,
    Thanks for the info, I'm struggling to understand what's happening in your code.
    This is also for a repeater, I'm trying to program 3 different modes, the first being basic users so no access code is required, this works fine, next I want an advanced user section which is only active after a pass code is entered and finally the keepers section which is only active after another different passcode.
    So i have the system working except for the 2 passcode areas which i'm using the lookdown which doesn't seem to be working and i'm, not sure why.
    If I save a value .. lets say 1 into a var named code
    then I use the following line
    LookDown code,["0,8,1,4,2,9,3"],J
    Surely the var J should then have the value of 2
    Am I correct?
    If so this is not happening and I dont know why.
    I'm unclear as to how your system is looking for a passcode.
    Jim
    Jim, Tones(*) is an array for storing the incomming touch tones. The first 4 tones are the password. The tone is decoded into a nibble of either 0,1,2,3,4,5,6,7,8,9,a,b,c,d,e,f. These are shifted into a word sized variable called codewrd. After all 4 tones are shifted into codewrd it is compared to a constant called unlock. It once again can have a value of 0000 to ffff. If the two compare then the system is unlocked...... This same type of method can be used for even longer unlock codes.
    m0cke's Avatar
    m0cke Guest
    Hi Dave,
    OK I'll look a little more in depth at the code.
    For now I have scrapped the lookdown table and i've gone with a simple code as follows:-
    IF dtmf = 4 Then 'First code digit
    gosub Getdtmf
    goto error
    IF dtmf = 1 Then 'Second code digit
    gosub Getdtmf
    goto error
    IF dtmf = 7 Then 'Third code digit
    gosub Getdtmf
    goto error
    This seems to work OK, but I have no option of changing the code remotely.
    How could I store the codes and re-program them remotely from the DTMF decoder?
    Jim
