LOOKDOWN command question
Results 1 to 2 of 2
    Jan 2006
    New Hampshire, USA
    Default LOOKDOWN command question
    Chuck Hellebuyck's book states that the command is: LOOKDOWN search, (constant {, constant}), var. 'search' is a word or bit that is searched for a match to 'constant'. If a match is found, the position of the matched constant is stored in 'var'. Zero = first constant, 1 = second constant, etc. What happens if no match is found?
    Mar 2005
    Iowa, USA
    Post
    The PBP manual states:
    Thus, if the value is found first in the list, Var
    is set to zero. If second in the list, Var is set to one. And so on. If not
    found, Var remains unchanged.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
  1. Need more speed in Lookdown and Branchl instructions
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 23:04
  2. DTMF Decode with Mitel 8870 & 16F628
    By m0cke in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2004, 07:44
