Serial Question
Results 1 to 5 of 5
Thread: Serial Question
    Feb 2003
    Just guessing that instead of the pin having the two states
    OUTPUT HIGH
    OUTPUT LOW
    it achieves Open Collector functionality by having the two states
    INPUT (high impedance so effectively open collector)
    OUTPUT LOW
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jun 2005
    Default You May Be Right!
    Keithdoxy, you may be right! That's interesting because what you suggest says that ON1200 may instantly change the pin to an input when the bit needs to be high (1) and then changes back to an output to go low (0) in sending the bit stream. Therefore emulating an open collector via the input state when a high (1) is needed. That would help me out because in some programs (using N1200 for example) I have been making the pin an input after sending serial data out because of parallel serial lines. The "O" may take care of that at a bit level.
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 03:49
  2. serial LCD/SLCD question
    By MatthewM in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 14:56
  3. Replies: 8
    Last Post: - 22nd July 2008, 20:31
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:39
  5. newbie with serial com question...
    Last Post: - 16th December 2006, 05:34
