Serial Question
Results 1 to 5 of 5
Thread: Serial Question
    Jun 2005
    Default Serial Question
    Hi. Can someone please tell me the operational difference between serial setting of for example N9600 compared to ON9600? I understand that "ON9600" is meant for use on an open collector port but how would it operate differently than N9600?
    penelopepug, The use of "open collector" circuits is for "ORING" other devices attached to the bus. The bus would have a passive pullup resistor to source the current required to drive the bus high. That way any device on the bus could pull it low by an open collector transistor or fet there by sending the signal to all devices that are listening. On a bipolar driven bus each of the devices will "sink or source" current at any time so you can have only 1 device in this mode, otherwise you would have bus contention meaning 1 device would be "sourcing" current and 1 device would be "sinking" current at the same time. HTH
    Jun 2005
    Thanks Dave. I understand the use of an open collector output however what I do not understand is if for example; If I use Porta.4 of a PIC16F877 as my serial output, since it is an open collector output, how would setting the baud to ON1200 differ from N9600? A pull-up is required on the open collector so would N9600 not act exactly the same as ON9600? What does the open collector designation "O" do?
    Feb 2003
    Just guessing that instead of the pin having the two states
    OUTPUT HIGH
    OUTPUT LOW
    it achieves Open Collector functionality by having the two states
    INPUT (high impedance so effectively open collector)
    OUTPUT LOW
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jun 2005
    Default You May Be Right!
    Keithdoxy, you may be right! That's interesting because what you suggest says that ON1200 may instantly change the pin to an input when the bit needs to be high (1) and then changes back to an output to go low (0) in sending the bit stream. Therefore emulating an open collector via the input state when a high (1) is needed. That would help me out because in some programs (using N1200 for example) I have been making the pin an input after sending serial data out because of parallel serial lines. The "O" may take care of that at a bit level.
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 04:49
  2. serial LCD/SLCD question
    By MatthewM in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 15:56
  3. Replies: 8
    Last Post: - 22nd July 2008, 21:31
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  5. newbie with serial com question...
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 16th December 2006, 06:34
