LCD help
Results 1 to 15 of 15
Thread: LCD help
    Sep 2005
    Dayton, Ohio
    Matrix Orbital is a "serial" LCD I think??
    Make sure you do NOT use the LCDOUT command. It only works with parallel LCDs. But that is where the "Hello World" example is in the PBP manual.
    If it IS a serial LCD then you should use one of the SEROUT type commands to write to it.
    Jim
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    HCSTechy's Avatar
    HCSTechy Guest
    it is serial, and we already tried using the serout command.
    This is the code we used:
    Pause 1000
    start:
    SEROUT portb.1, 1, [254,1] 'supposed to clear screen
    pause 40
    serout portb.1, 1, ["hello world"]
    pause 400
    goto start
    in the book for the lcd, it says that the command for clear screen is 254 88,
    but it doesn't work either
    How have you connected the Serial port of the PIC to the Serial input of the Display?
    Have you used any rs232 converters like MAX232?
    Dec 2003
    Wichita KS
    What you may want to do, is one of two things...
    put a character spacing of 1000 (defined at top of program),
    or instead of Looping to the very beginning. Loop to the output again...
    You may be transmitting data too fast for the LCD to respond, and hit the clearLCD before bring printed.
    using your code with a slight mod:
    DEFINE CHAR_PACING 1000
    Pause 1000
    start:
    SEROUT portb.1, 1, [$FE,1] 'supposed to clear screen
    pause 40
    Loop:
    pause 400
    goto Loop
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    HCSTechy's Avatar
    HCSTechy Guest
    thanks dwayne,
    i wont be able to try that until monday...
    but I'll definetly let you know if it works
    HCSTechy's Avatar
    HCSTechy Guest
    no it didnt work
    it keeps displaying a character that looks like two I's over and over again
    but its at least doing something different than before
    be sure of your baudrate AND the way you need to send the data to your LCD. I mean Inverted or NotInverted
    Wich crystal speed you use?
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
