LCD help
Results 1 to 15 of 15
Thread: LCD help
    HCSTechy's Avatar
    HCSTechy Guest
    Red face LCD help
    I am using a PIC16F84A pic and I am having LCD problems, I tried using a code that makes the LCD say "Hello World" and it doesnt work.
    Can one of you nice people tell me how to fix this problem.
    We've tried to use the code from the LCD manual to clear the screen, but it has a semi-colon so it declares part of the code as a comment/remark.
    so we couldnt use that. We also tried using the code that was explained in the picbasic command book. But it didn't work either.
    Any help would be greatly appreciated.
    Dec 2003
    Wichita KS
    First off...
    Can you verify your LCD is working?
    Even by adjusting contrast to see dark squares, is better than nothing...
    Then you must verify your chip is sending data propery...
    You can use LED's on the port to make sure your data is being sent. If you send a "1", you had better see the binary "1" with the lit up LED's.
    If the above is working, then you must make sure you initialize the LCD before using, and give a "pause" before sending commands to the LCD.
    A pause 100 will give the LCD time to wake up.
    What does your code look like? (I don't mean just a copy out of the book, but I mean what YOU used to program your pic with.).
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    HCSTechy's Avatar
    HCSTechy Guest
    Question
    The LCD does work, when we make the circut and everything all that is shown is the name of the LCD (Matrix Orbital) and a strange character at the begining of the first line, the PIC works, we did other programs on it, and we also did a pause but not at 100, we might try that.
    Sep 2005
    Dayton, Ohio
    Matrix Orbital is a "serial" LCD I think??
    Make sure you do NOT use the LCDOUT command. It only works with parallel LCDs. But that is where the "Hello World" example is in the PBP manual.
    If it IS a serial LCD then you should use one of the SEROUT type commands to write to it.
    Jim
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    HCSTechy's Avatar
    HCSTechy Guest
    it is serial, and we already tried using the serout command.
    This is the code we used:
    Pause 1000
    start:
    SEROUT portb.1, 1, [254,1] 'supposed to clear screen
    pause 40
    serout portb.1, 1, ["hello world"]
    pause 400
    goto start
    in the book for the lcd, it says that the command for clear screen is 254 88,
    but it doesn't work either
    How have you connected the Serial port of the PIC to the Serial input of the Display?
    Have you used any rs232 converters like MAX232?
    phan's Avatar
    phan Guest
    I'm actually having the same problem as you do. I'm using the LCD2041, and nothing seem to work. My pic chip is the 16F876.
    did you solder the pins on your LCD for TTL communication ?
    let me know your latest findings
    badrad's Avatar
    badrad Guest
    Quote Originally Posted by phan
    you need to confirm which version of pcb you are using, their documentation does not always reflect the latest PCB version. I've used their GLC24064 - connected to 16F876A and 877A in TTL serial and have also tested with their I2C. Using TTL setup with the display, just make sure you do not invert the PIC serial signal.
    BTW-the Orbital Matrix displays sometimes hiccups in it's receive buffers, and depending on your application, the display may occasionally wander off into oblivion. Check their forum, there are some threads about this.
    badrad's Avatar
    badrad Guest
    sorry - timed out and wound up double posting the reply...
    HCSTechy's Avatar
    HCSTechy Guest
    We fixed the problem, thanx everybody.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. LCD will not start
