Need Help On Ac Voltmeter !!
Results 1 to 22 of 22
    boboco's Avatar
    boboco Guest
    Default AC Voltmeter
    Hi Sougata,
    I don't use the ADCIN command either, unless I'm feeling lazy or there is no need not to. I switch the registers as required. Especially in many uses (I research in Laser Medicine and build a lot of my own equipment) a different integration time for different inputs can be of benefit.
    I even connect CCD array outputs directly to the ADC input and get excellent results by using the input circuitry in the PIC as a quasi charge measurement device. Set the reference voltages to, say, +3V and +1V and we get a good resolution. We don't even need to decouple the input, the charge function of the input capacitor does that.
    Rob
    Apr 2005
    No problem for Delay!
    we are looking forward your sch. & code sample!
    thx
    boboco's Avatar
    boboco Guest
    Hi Uludere,
    I forgot the week-end, I got round to trying to get the data over to you but using Eagle CAD, I can't get a file under 200K, so now I'll try it in little bits. First of all the simple input for chunking AC attached.
    Using a 2.4 volt zener diode D1 and R1- 1.0K, generate 2.4V as offset for the PIC input, decouple with C1, C2 from Vdd against Vss. This is also connection for one of the meter probes. Remember that both Vdd and Vss must float, the probes may not come into contact with Vss or Vdd.
    The resistors R2 and R3 must be calculated as divider for the max. voltage you want to measure. If e.g. you want to measure max. 100 VAC RMS then calculate 100 x 1.42 = 142V say 150 V peak each node and select the resistors accordingly to allow not more than +/- 2.5V at the PIC input. I've put a 100nF capacitor over the PIC input to reduce noise, if you keep the frequency under ca. 100-150 Hz it won't affect the input materialy.
    If you now put the probes over the voltage you want to measure, the reduced signal divided by R2 and R3 2 will appear over the ADC input offset at 2.4 V.
    Let me know when or if you want to try this type, I'll send you software or the next circuit if you want to try the RMS method.
    Greetings,
    Rob
    Apr 2005
    thx for your kind response..
    i want to try the RMS method, would you mind sending about it ?
    if the file is big , you can send to my email adresss.. [email protected]
    onur's Avatar
    onur Guest
    Hi
    Can we see rms method?
    Mar 2006
    Talking schematics
    Sir:
    Good day to you sir
    To measure low AC voltages (< ca. 10V) accurately by rectification it is necessary to use ideal diodes. Normal diodes will have a forward drop voltage of ca. 0.6V (silicon) or ca. 0.3V (germanium). Best here is to use two OPs with diodes in the feedback, trimmed to 0V. For those who wish, I will be happy to supply circuits etc.
    Sir, I would be grateful if you would provide me the schematics
    Yours trully,
    Ryan
  1. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  2. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 12:02
  3. Ac voltmeter Ampermeter
    By onur in forum General
    Last Post: - 27th March 2007, 21:13
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 07:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 21:31
