Need Help On Ac Voltmeter !!
Results 1 to 22 of 22
    Apr 2005
    Quote Originally Posted by boboco
    Hi Uludere,
    If you're intending to use a PIC with ADC such as e.g. the 16F87* and you want to measure directly then it's only a question of the frequency you are dealing with and the speed of the PIC oscillator. If you are prepared to do a little circuit work and you don't need to read the frequency you can rectify the AC line and simply measure the DC component, which is easier and requires much less code.
    It's no problem, though. Let me know what range of voltage and frequency you're interested in and I'll send you info.
    Greetings,
    Rob
    I want to measure upto 300 V AC/ 50 Hz. I have 16f877 20 MHz ..
    but any other appliction maybe helpfull !!
  1. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  2. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 13:02
  3. Ac voltmeter Ampermeter
    By onur in forum General
    Last Post: - 27th March 2007, 22:13
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 22:31
