Couldnt read hex file extension
Results 1 to 5 of 5
    sooyewguan's Avatar
    sooyewguan Guest
    Default Couldnt read hex file extension
    I wrote my program using MPLAB 7.3 using picbasicpro assembler. But when I compile the program, MPLAB prompt that "Couldnt read the hex file, incorrect extension".
    How can I solve the problem ?
    I am using Microchip ICD2 to download my program, how do I use Microcode and select ICD2 as programmer ?
    Thanks first.
    Jan 2006
    Istanbul
    Cool
    I think you are describing the problem incorrectly.
    Try "compile only" instead of "compile and program" then check the hex file if it is there.
    After that, pls describe the problem again.
    sooyewguan's Avatar
    sooyewguan Guest
    I just click compile. But the MPLAB will automatically load the hex generate by the assembler.
    The hex file was created successfully, but I think the format is not supported by MPLAB.
    Jan 2006
    Istanbul
    Cool
    Ok. Now try using another PIC programming software.
    You already have the generated hex file. Since all hex files are supported by all PIC programming software, it should not be a problem for you to use another software.
    Just make sure that the software you choose supports your PIC.
    sooyewguan's Avatar
    sooyewguan Guest
    Thanks sayzer. Could you recommand any software the support microchip ICD2 programmer to me ?
  1. Configuration bits in a HEX file gone missing?
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2010, 02:10
  2. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. INH8XM HEX file structure
    Last Post: - 30th December 2006, 23:46
  5. No hex file...?
    By mypylon in forum mel PIC BASIC Pro
    Last Post: - 28th November 2005, 15:02
