RTC date problem
Results 1 to 8 of 8
    Hi Peder,
    I dont think reading the chip every second should be an issue; I have used a PCF 8563 in a propeller clock that gets polled far more frequently, and there is no problem.
    I am attaching a snippet using PBP with the PCF8583 that I had downloaded some time ago; this might lead you in the right direction.
    Anand
    Aug 2005
    South Africa
    Thanks man, by checking your code and comparing it to mine, I realised that I made my "DAY" variable WORD instead of BYTE. It works perfectly now...
    Thank you for your help and time.
    Cheers
    Mentor, Ohio
    Smile
    Hi ardhuru,
    Would it be possible for you to post the rest of the code for the RTC including time setting? I think many people on this forum would be interested as there have been some posts requesting specifically this chip.
    Thank you very much!
    BobK
    Default RTC read and RTC write
    Hi Bob,
    Actually, I used the PCF8563, which is virtually identical to the PCF8583 except for a few features.
    Anyway, here are the RTC read and RTC write segments that I use. Since my RTC works on a battery (a CR2032, now in its second year, expected to go on for at least a year more!), I have also extracted the low battery indiactor bit.
    'READ FRESH VALUES FROM THE RTC and convert BCD to decimal
    I2CREAD SDA,SCL,$A2,2,[S,m,h,D,W,MN,Y] 'Read all parameters from the RTC
    LOBATT = S & %10000000 ' Mask off all bits unimplemented in RTC registers
    S = S & %01111111 '
    M = M & %01111111 '
    h = H & %00111111 '
    D = D & %00111111 '
    Mn = Mn & %00011111 '
    TMP=S ' Convert BCD to decimal
    S=((tmp>>4)*10)+(tmp & $0F) '
    tmp=M '
    M=((tmp>>4)*10)+(tmp & $0F) '
    tmp=H '
    H=((tmp>>4)*10)+(tmp & $0F) '
    tmp=D '
    D=((tmp>>4)*10)+(tmp & $0F) '
    tmp=MN '
    MN=((tmp>>4)*10)+(tmp & $0F) '
    tmp=Y '
    Y=((tmp>>4)*10)+(tmp & $0F) '
    'Convert Decimal Seconds,Minutes & Hours values to BCD equivalents and write to RTC
    tmp=S
    S=(tmp dig 1<<4)+(tmp dig 0)
    tmp=M
    M=(tmp dig 1<<4)+(tmp dig 0)
    tmp=H
    H=(tmp dig 1<<4)+(tmp dig 0)
    tmp=D
    D=(tmp dig 1<<4)+(tmp dig 0)
    tmp=MN
    MN=(tmp dig 1<<4)+(tmp dig 0)
    tmp=Y
    Y=(tmp dig 1<<4)+(tmp dig 0)
    I2CWRITE SDA,SCL,$A2,2,[S,M,H,D,W,MN,Y] 'Write parameters to RTC
    Hope this helps!
    Anand
    Mentor, Ohio
    Smile
    Hi Anand,
    Thank you!
    BobK
  1. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
  3. 8583 rtc date problem
    By crazyhellos in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 15:28
  4. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:54
  5. RTC Problem
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 11th March 2006, 05:13
