RTC date problem
Results 1 to 8 of 8
    Aug 2005
    South Africa
    Default RTC date problem
    Hi, I am working with a PCF 8583 real time clock. I can read and write to the device correctly, but as soon as the time changes to 00:00:00, the day and month gets incremented by the RTC automatically. I have tried changing the RTC, but the same thing happens.
    Can anyone help me?
    Are you sure you are masking off the unused bits in the month and date registers while reading/writing?
    You can expect bizarre things if you are simply reading (or writingto) the whole register(s).
    Anand
    Aug 2005
    South Africa
    Yes, I have masked it ( I2CWrite DPIN,CPIN, RTC,$00,[ $09 ] ).
    Could it be because I'm reading the RTC every second, it is confuses the RTC when it wants to update the date the same time as I'm trying to read it?
    Hi Peder,
    I dont think reading the chip every second should be an issue; I have used a PCF 8563 in a propeller clock that gets polled far more frequently, and there is no problem.
    I am attaching a snippet using PBP with the PCF8583 that I had downloaded some time ago; this might lead you in the right direction.
    Anand
    Aug 2005
    South Africa
    Thanks man, by checking your code and comparing it to mine, I realised that I made my "DAY" variable WORD instead of BYTE. It works perfectly now...
    Thank you for your help and time.
    Cheers
    Mentor, Ohio
    Smile
    Hi ardhuru,
    Would it be possible for you to post the rest of the code for the RTC including time setting? I think many people on this forum would be interested as there have been some posts requesting specifically this chip.
    Thank you very much!
    BobK
  1. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
  3. 8583 rtc date problem
    By crazyhellos in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 15:28
  4. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:54
  5. RTC Problem
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 11th March 2006, 05:13
