Help with upgrading from PIC Basic Compiler to PIC Basic PRO
Results 1 to 6 of 6
    The batteries are out in my crystal ball Erik. It would help if you could tell us what PIC you're using and post your super new and shiny blinky LED code... I need a laugh this morning....
    Jan 2006
    Well, I'm using a 12F675 and heres one of several that haven't worked:
    CMCON = 7 ' Comparators OFF
    ANSEL = 0 ' A/D OFF
    loop: High GPIO.1 ' Turn on LED connected to PORTB.0
    Pause 500 ' Delay for .5 seconds
    Low GPIO.1 ' Turn off LED connected to PORTB.0
    Goto loop ' Go back to loop and blink LED forever
    Jan 2006
    PS: I forgot to change the comments regarding the port numbers. But I'm wondering about stuff like at the moment I'm running both PBC and PBP on the same computer and it doesn't seem to be a problem but maybe it is. I mean I'm obviously missing something at a basic level here, because all my PBCing was going just fine. Anyway, its getting late on this side of the panet and I'm burnt out from surfing so I'm going to bed. Catch you later, and thanks for any help/suggestions that might help get my LED's blinking again.
    Well, since you got a grown-up compiler, we might as well do things properly...
    	'	PIC Defines
    	@ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    		' System Clock Options (Internal)
    	@ DEVICE pic12F675, WDT_ON
    		' Watchdog Timer
    	@ DEVICE pic12F675, PWRT_ON
    		' Power-On Timer
    	@ DEVICE pic12F675, MCLR_OFF
    		' Master Clear Options (Internal)
    	@ DEVICE pic12F675, BOD_ON
    		' Brown-Out Detect
    	@ DEVICE pic12F675, CPD_OFF
    		' Data Memory Code Protect
    	@ DEVICE pic12F675, PROTECT_OFF
    		' Program Code Protection
    	'	Hardware Defines
    	LED var GPIO.1
    	'	Initialise PIC
    	TRISIO=%00001000	' All Output except GPIO.3
    	CMCON=%00000111 	' Disable Comparators
    	ANSEL=%00000000 	' Disable ADC
    	'	Let's do Blinky Thing...
    Start:
    	Toggle LED
    	Goto Start
    Compile using the command line...
    PBP -p12F675 myprog -v
    Then if you want to be exotic with your 12F675 download yankeedoodle from here...
    http://www.picbasic.co.uk/forum/showthread.php?t=64
    Jan 2006
    Thanks for your help, It looks like I was neglecting the defines (I was setting the fuses with my programmer, but they were obviously getting over-written). It looks like the reason all my stuff was running on PBC was that the INC file didn't turn MCLR on where as my new grown up compiler uses an INC file which turns it on (hmmmm). Anyway, now I am ready to seriously blink some LED's also thanks for the sound tables that was going to be my next question.
  1. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 13:18
  2. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 07:14
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 00:52
  4. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  5. PIC Basic Pro Compiler
    By iclok in forum mel PIC BASIC Pro
    Last Post: - 25th November 2005, 03:22
