LINX RF module and PIC
Results 1 to 10 of 10
    Default LINX RF module and PIC
    I have a pair of 16c65B, one as a xmtr using serout and the other as a rcvr using serin.
    When I hardwire the output pin to input, everything works great. I normally have an optoisolator in there and it works fine either way...with or without.
    I bought a LINX ES 916mhz xmtr and rcvr module and was hoping that it would be a simple plug and play but so far, no luck.
    I have a scope connected to the data output on the rcvr module....the data is there and looks fine but when I connect to the rcvr pic (or the opto), I lose the waveform and get nothing.
    I tried some series resistance, which gets the waveform back but still no action on my rcvr.
    Could someone tell me what I'm doing wrong?
    It has to be something simple.
    I even inverted the data for the heck of it but obviously this is an interface problem as I'm losing signal completely.
    --thanks
    I did now just notice one thing that may play a part.
    I'm using A4 as my input pin for SERIN on the rcvr and I know it's a schmitt trigger input (didn't know that before I did the pc board).
    But like I say....if I hardwire....everything is fine.
    I'll try another input and see but I don't think that's it.
    actually, come to think of it, I made porta.4 serin BECAUSE of the schmitt trigger.
    works wired...just not with the linx.
    On most PICs RA4 schmitt trigger inputs require a minimum input level of around 0.8 * Vdd to be recognized as a logic 1. Assuming you're running right at 5V, this would be around 4V.
    The Linx ES series receiver data output level for a logic 1 is around Vcc - 1.1 min, Vcc - 1 typical, or Vcc - 0.9 max. You only have around 3.9V min to ~4.1V max. Best case is around .1V above the minimum level required by RA4, so this could be a problem.
    A TTL input would have been nice, but you can always use an FET or transistor.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Both my linx rcvr and the pic are powered by 5v supplies (seperate) so I sort of ruled out a threshold problem but I thought of just using a transistor buffer last night to see if that solves it.
    I thought the linx out and the pic input would be compaible as most schematics
    I've seen show a direct connection.
    It's like when I connect the linx, it just shorts out the signal completely.
    I'm gonna goof with it later....I'm sure it will be something stupid.
    Well....I tried a buffer into the pic (inverted and not)...plenty of data on the SERIN pin and still nothing.
    I don't get it....it works perfectly with a wire pair but nothing with the Linx.
    How important is a squelch circuit?
    I'm not using one.
  1. Using Linx RF modules ?
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 8th September 2009, 15:45
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. RF module help
    By greensasquatch in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 19:50
  4. LINX RF module and PIC (#2)
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2006, 18:56
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
