Learning in the process. Thanks for the heads up. I think that is were I was getting the mistake or the headache.
I have attached the whole prgram that I am trying to use. The problem that I am having starts with labels LIMITSA. I think that the whole problem that I am getting is with that .5
The other thing is that I am using a linear equation to solve for a result in the range of 1 to 2. With the label PROGRAM2 you can see that I have 510 with part of the equation, but it should all come back and relate to that range of 1-2. will this be a problem.
The equations that I would like to base all of this off of is the second line to label PROGRAM1 and PROGRAM2. The difference between the two is that of the slope.
