PBP compatible with Velleman k8048 programmer?
Results 1 to 6 of 6
    Zeke's Avatar
    Zeke Guest
    Melanie,
    I agree that the Velleman is not very versatile and only programs a few of the many pics available. But.... if one is experimenting and creating only a few small prototype projects it will work OK.
    My very first programmer was the Velleman kit, and to date, it has worked well. Of course, I only program PICS occassionally and only stick with designs that I can program, but there's enough that I can do with this programmer to keep me busy for a long time considering I only do this between work, family, and every thing else I need to do around the house.
    Having said that, a more versatile programmer would be better, but so far, my projects include:
    1) Automatic remote flash trigger for my digital camera, 12F629
    2) Heart Rate Monitor with output via RS232 to PC or Palm using the 16F627
    3) Voltage and current 4 digit LED display (multiplexed) for a desktop power supply using the 16F819
    4) Accelerometer using an ADXL202 with PWM output and the 16F628.
    Of course, the invaluable help available on these forums makes things a lot easier!!!
    Again, these aren't very complicated, but not bad for a weekend programmer and a very limited selection of PICS.
    Henque19's Avatar
    Henque19 Guest
    Thanks everyone, think I'll go for the velleman-kit for now, and if I'm still keen in a few years, I'll upgrade to a proper one. Programming 3000 different PICs isn't really something crucial for me at this point.
    /Henrik
    Thumbs down "Wich is the best" thread not asking to the question...
    Hi, Henrik
    As you get an Hex file from PbP, it's not a problem to use that programmer ...it won't program automatically the chip, just call back the hex file to your programmer's soft ...
    If config bits are not available by your programmer soft, you can even modify them in PbP files ... ( a bit boring, but it works !!! )
    What you must look at is wich Pic are supported :as Zeke says, many, many projects can be realised with a limited range of processors.
    I've mainly used 12F683, 675, 16C84, 16F84, 16F628, 16F648, 16F876 and 16F877 at this day. They cover over 80 projects, mainly for R/C stuff .You will see those processors are supported by lots of " simple " and " old " programmers.
    Many times, your brain will show you simple solutions to use very basic processors instead of " up to date " unavailable power monsters, just adding some logic or analog circuit around.
    As you're not a professionnal ... some ( really few ) more bucks or Euros in a project is not a problem ...
    One day, may be you'll get a " Picmonsterprog Plus More Over " on Ebay ... and you' ll write on this Forum :
    " I have a 18F8722 , .... I need help for setting Timer 0 or I/Os ..."
    ... Humour !!!
    Good progs,
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
  4. Using PBP Hex Files with FED Pic Programmer
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 20th February 2005, 10:57
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 18:16
