I need to get hex values, such as hex55, hex03,hex40 as a string out to PORTB.4 for a 16F628 using PBP.The communication should be 8N1 true, no parity. What I'm up to is attempting to drive a small serial H bridge driver. I have tried various string code with different DEFINES and INCLUDES and none has worked. At best there is a small hum from the motor. I put the H-bridge back on the BS2 dev. board using Stamp code and it runs perfectly. If someone could post a SEROUT hex string example it would help. The PBP manual seems a bit vague regarding communication strings.Thanks JS
