Communication PIC to PIC?
Results 1 to 20 of 20
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    SERIN2 serpin,36081,300,Main,[Wait ("A"),dec3 B7]
    could the line above be explain in a little more detail. I follow to what you are to do, but I just do not understand it. I am trying something on my end with SERIN and SEROUT, but I think that I might have to switch to this SERIN2 and SEROUT2. Might make life easier. Who know.
    Mentor, Ohio
    Smile
    Hi Rhatidbwoy,
    SERIN2 is fully explained on page 132 of the PBP manual. Serpin is the alias I have assigned to PortA.4 which is where the data will be received. 36081 is the mode of communications I am using derived from the Appendix A on page 201. 300 stands for 300ms which is the timeout for a signal to be received. If no data is received within the 300ms then GOTO Main. Wait ("A") tells the system to wait until the character "A" comes in. This is known as a qualifier. The dec3 tells SERIN2 to convert the decimal value in ASCII and store the value in variable B7.
    I truely am not an expert like some of the other people on this forum and I am sure that they can give a more thorough explaination, but what I learned here comes from the manual and trying different things.
    BobK
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    ok that is great help. The method that I am coming across to use is the HSER--- command.. The USART on hte device. I think that will clarify more to what I need to do, but still the problem with transmitting. I found info about that and it helps more than were I stand.
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    Another Quick one. I am trying to get HSERIN and HSEROUT to work. have you done anything with them. I have attached portion of my prog. does this even look right as far as direction wise.
  1. 2 PIC, serial communication
    By lightgreen in forum Serial
    Last Post: - 21st November 2009, 16:20
  2. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 21:02
  3. PIC 2 PIC communication
    By Mario in forum Forum Requests
    Last Post: - 28th April 2006, 02:56
  4. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
  5. Pic to Pic communication?
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 11th April 2004, 20:41
