LCD Control
Results 1 to 29 of 29
Thread: LCD Control
    Sep 2005
    hi there iam not sure what you mean can you explane
    Wink try
    when i have a problem with the lcd display
    it has been the fact that i use a 20 osc
    and what works for me is to change line
    define lcd_dataus 50
    to
    define lcd_dataus 200
    it just works for me
    Sep 2005
    hi there thanks for the reply.
    how do you know your lcd is in working order, i have ready that if you just provide power to it you should see black boxes is this true. i tried this and all i get is the backlighting up but no boxes.
    Quote Originally Posted by Jhdgkss View Post
    Power to LCD - pin 1 ground, pin 2 is 5 volts positive, pin 3 center lug of contrast pot. these are the primary power leads, pin 4 R/s bit, pin 5 R/w and must be as mister_e said ground etc etc . . . now pin 15 Power for LED backlight, pin 16 LED backlight ground. Just because led backlight is on does not mean lcd is powered.
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. 4x40 LCD control problem
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 12:43
