LCD Control
Results 1 to 29 of 29
Thread: LCD Control
    Smile more info
    not a expert but my problems has always been with using a higher speed osc
    and not reseting lcd_dataus to match the crystal more delay for higher speeds just a thought
    Sep 2005
    hi there iam not sure what you mean can you explane
    Wink try
    when i have a problem with the lcd display
    it has been the fact that i use a 20 osc
    and what works for me is to change line
    define lcd_dataus 50
    to
    define lcd_dataus 200
    it just works for me
    Sep 2005
    hi there thanks for the reply.
    how do you know your lcd is in working order, i have ready that if you just provide power to it you should see black boxes is this true. i tried this and all i get is the backlighting up but no boxes.
    Quote Originally Posted by Jhdgkss View Post
    Power to LCD - pin 1 ground, pin 2 is 5 volts positive, pin 3 center lug of contrast pot. these are the primary power leads, pin 4 R/s bit, pin 5 R/w and must be as mister_e said ground etc etc . . . now pin 15 Power for LED backlight, pin 16 LED backlight ground. Just because led backlight is on does not mean lcd is powered.
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. LCD will not start
  5. 4x40 LCD control problem
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 11:43
