LCD Control
Results 1 to 29 of 29
Thread: LCD Control
    boboco's Avatar
    boboco Guest
    Default LCD Control
    Hi all,
    thanks for the help.
    Curious is that the first line functions exactly as it should in every way, only the second line not. If I turn the contrast up to maximal all pixels turn black, though, so at least the line isn't dead.
    I've temporarily replaced the Displaytech with another type of unit. (all that work...., sob!) It worked at once so I take it that the Displaytech is bugged in some way. I've ordered a new one and hope that that will work, otherwise I'll have to change the whole construction to use some other. I'll report when I've got the results.
    Another short question on LCD control +PBP. If I want to control a 4 liner, which is essentially two complete LCDs in one, I've been doing it by switching both enable lines via resistors from one port and shorting each of the enable lines respectively with another two ports to disable it.
    It must be possible to program the PIC so that the selection of two enables is directly possible. (DEFINEs?) I've looked on the board but haven't found anything. Any ideas?
    Greetings
    Rob
    Italy
    Your display is not correctly initialized.
    (This is why you get only one line).
    In order to use your LCD (KS0070b), you will have
    to manually initialize the KS0070b before you call the
    first PicBasic LCDOUT.
    Below you can find the pseudo code + a table.
    Best regards,
    Luciano
    See PDF page 32 for the initialization of the KS0070B in 4 bit mode
    http://www.ee.oulu.fi/research/tklab...river-3316.pdf
    KS0070b Initialization
    2x16 LCD (KS0070b)
    4 bit mode
    2 lines
    Display=on
    Cursor=off
    Blink=off
    Increment mode
    Entire shif=off
    (Pseude-code, same as the table below).
    Power on
    (PIC and LCD module).
    Wait 40 ms
    (Function Set)
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0010
    Toggle the Enable line:
    PULSOUT Enable_Pin,100 (min.100 µs)
    Set the LCD pins:
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 1000 (2 lines, 5x7 dots)
    Wait 100 µs
    (Display On/Off Control)
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0000
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 1100 (Display on, cursor off, blink off).
    Wait 100 µs
    (Clear display)
    Set the LCD pins:
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0001
    Wait 2 ms
    (Entry Mode Set)
    Set the LCD pins:
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0110 (Incremet mode, entire shif off).
    Wait 2 ms
    End of the KS0070b Initialization.
    boboco's Avatar
    boboco Guest
    Thumbs up LCD Control
    Hello Luciano,
    Thanks, Pal. Now it works. And I've learnt something new.
    Best greetings,
    Rob
    Sep 2005
    i two have purchased an lcd that uses a k0007b criver chip i tried you example of initalising the display manualy not notheing hear is my code can some one check it for me please.
    '* Name : LCD template.BAS *
    '* Author : John Hodgkiss *
    '* Notice : Copyright (c) 2007 John Hodgkiss *
    '* : All Rights Reserved *
    '* Date : 17/03/2007 *
    '* Version : 1.0 *
    '* Notes : *
    'Template program for LCD useing a K0007b driver chip
    'KS0070b Initialization
    '2x16 LCD (KS0070b)
    '4 bit mode
    '2 lines
    'Display=on
    'Cursor=off
    'Blink=off
    'Increment mode
    'Entire shif=off
    start:
    'Power on
    'set variables
    output portA
    Db7 var byte
    Db6 var byte
    Db5 var byte
    Db4 var byte
    RS var byte
    E var byte
    PauseA var byte
    PauseC var byte
    'set constants
    PauseA = 10 ' 100us
    PauseC = 200 ' 2ms
    'define
    DEFINE LCD_DREG PORTA 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA 'LCD register select port
    DEFINE LCD_RSBIT 5 'LCD register select bit
    DEFINE LCD_EREG PORTA 'LCD enable port
    DEFINE LCD_EBIT 4 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    pause 400 'pause for 40ms for lcd to start up
    'set pins
    Db7 = portA.3
    Db6 = portA.2
    Db5 = portA.1
    Db4 = portA.0
    RS = portA.4
    E = PortB.3
    output portA
    Output portB
    portA = low
    PortB = low
    setup:
    DB7 = 0
    DB6 = 0
    DB5 = 1
    DB4 = 0
    'Toggle the Enable line:
    PULSOUT E, 100
    pause PauseA
    E = low
    DB7 = 0
    DB6 = 0
    DB5 = 1
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    'set 2 lines 5x7 dots
    DB7 = 1
    DB6 = 0
    DB5 = 0
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    pause PauseA 'pause 100us
    'turn display On/Off control
    DB7 = 0
    DB6 = 0
    DB5 = 0
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    'Display cursor off, blink off
    DB7 = 1
    DB6 = 1
    DB5 = 1
    DB4 = 1
    PULSOUT E, 100
    pause PauseA
    E = low
    pause 10 ' wait 100us
    'clear display
    DB7 = 0
    DB6 = 0
    DB5 = 1
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    DB7 = 0
    DB6 = 0
    DB5 = 0
    DB4 = 1
    PULSOUT E, 100
    pause PauseA
    E = low
    pause PauseC 'pause 2ms
    'Entry mode
    DB7 = 0
    DB6 = 0
    DB5 = 0
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    DB7 = 0
    DB6 = 1
    DB5 = 1
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    pause pauseC
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    is this correct??
    the dispaly does light up but thats it
    here is a link to the displays pdf file
    http://www.maplin.co.uk/Media/PDFs/N27AZ.pdf
    Sep 2005
    hi there again i have been up all night trying to get this thing working no luck can some one please have a lok at my code or does anyone know where a example piece of code is. please iam desperate
    Smile more info
    not a expert but my problems has always been with using a higher speed osc
    and not reseting lcd_dataus to match the crystal more delay for higher speeds just a thought
    Sep 2005
    hi there iam not sure what you mean can you explane
    Which compiler are you using? 'cause if that code above is PicBasicPro, you really, really need to get reading the PBP manual and learn it.
    You don't have any Black boxes????
    Or your contrast POT is crap, or you didn't installed it correctly.. or you forgot. ANY character LCD i know, once connected will produce those Black boxes.
    R/W pin is left floating in the air... must be tied to gnd
    Some LCD brand may need to tie unused DB<4:0> to Vss or Vdd... have a look to the datasheet
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. LCD will not start
  5. 4x40 LCD control problem
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 11:43
