LCD Control
Results 1 to 29 of 29
Thread: LCD Control
    boboco's Avatar
    boboco Guest
    Question LCD Control
    Hi All,
    I use PBP.
    I know this must be an old hat, but I've been trying this one for days. I'm using a Displaytech 162 LCD 2 x 16 on a PIC16F877 port d and, do what I will, I can't get it to write the second line. I've tried all sorts of DEFINES etc. without success.
    If I define the display as one line, which I still suppose it to be, first line is normal, second line nothing. If I define the device as 2 line, however, I get no display at all.
    Second line adress is given as 40H, but I've tried almost anything to no purpose.
    I've driven lots of LCDs with lots of PICs and had some problems, but this is new to me. Or is the display most probably defect?
    Can you provide any datasheet for us? sometime we feel lazy to search... at least me
    Italy
    Add 80h to the character address to make
    the Display Data RAM Address Set command.
    (When you add 80h you set bit 7).
    $00 + $80 = $80
    $40 + $80 = $c0
    LCDOUT $FE,$80, "Hello on line 1"
    LCDOUT $FE,$C0, "Hello on line 2"
    Best regards,
    Luciano
    boboco's Avatar
    boboco Guest
    Unhappy Lcd ??
    Hi Luciano, Hi Mister_e,
    I have already tried the code as you write, Luciano, it doesn't work on this unit but thanks all the same.
    If the unit isn't defect I'm wondering if the display controller chip is non-compatible to the Hitachi, it's a KS0070 but I believe it to be OK. I've got the data sheet in PDF and can send it to you if you require it, Mister_e. Checking through the command and address register it seems to be similar to the Hitachi controller. I'm beat.
    well, post your PDF here or the link to get it.
    boboco's Avatar
    boboco Guest
    Default Lcd
    Hi Steve,
    attached the PDF. Maybe you can find something. Thanks for the effort.
    Greetings,
    Rob
    boboco's Avatar
    boboco Guest
    Arrow PDF Fail
    Hi Steve,
    The file was too big, says BISOS.
    Here the link
    http://www.displaytech.com.hk/pdf/ch...series-v11.PDF
    Greetings,
    Rob
    by searching here and there this one is suppose to be PBP compatible without too much problem. At least the controller is suppose to be HD44780 compliant.
    Did you tried a longer start-up delay, let's say 2 Seconds at the top of the program?
    Do you have another LCD to test with your current set-up?
    What about the supply line? Clean and 5V?
    what about your current setup? Any schematic or picture of it?
    Maybe a simple hardware problem. unsufficient filtering or else.
    Feb 2005
    brookfield, ct, usa
    hi boboco
    Try adding a 10ms pause between the two LCDOUT statements. It's the only way I've been able to display multiple lines.
    boboco's Avatar
    boboco Guest
    Question LCD control
    Hi Steve, Hi Alec,
    Alec, I've tried all sorts of delays, or even different program parts, to write line 2, all without success, but thanks anyway.
    Steve, I usually allow 1 sec. startup, but trying 2 secs made no difference. The setup is a control circuit for medical laser x-y-z control containing analog and digital circuits. This model is supplied via laboratory power supply, is smoothed and filtered (100nF everywhere) and the line shows ca. 20 mV ripple in operation. The oscillator is decoupled from the VCC line because that causes lots of nasty noise usually. If you wish, I’ll send you the circuit diagram.
    The code is the usual:
    DEFINE LCD_etc…. ‘Setup LCD
    Pause 1000 ‘Settle pause
    LCDOUT, $FE, 1, “ Blah blah” ‘Write #1
    GOSUB somewhere ‘Fetch, calculate variable
    LCDOUT $FE, $C0, “ Blah “, DEC Variable ‘Display variable
    I haven't got another unit of this size and type, to take another type for test will involve (sigh) a large amount of work as this is built-in and direct connected. If I don't get it to work, though, I'll buy a new one eventually. I don't like getting beat, though.
    One point, I’m using a 16F877 and have the LCD defined to the D-Port as the only port free. I’m wondering if some register needs to be set/reset. I’ve been caught like that before. Is anything known? I’ve not found anything in the PIC Data book, but something with the parallel port control possible?
    Greetings,
    Rob
    Rhatidbwoy's Avatar
    Rhatidbwoy Guest
    I was having a problem with HANTRONIX 20 x4.
    I fixed the problem with a pause. In description to what I was getting was that I would get the second line to go and the fourth line to go. Not the first nor the third line to light. I played with many things, but what came to work was that I need a pause.
    When you write your first line you normally would not need a clear screen (lcdout $fe, 1). So the second thing would write. leaving nothing for hte first line. This is were the pause is needed. So it looks something like this:
    lcdout $fe,1
    pause 10 'what ever value. I used 10
    lcdout $fe, address (first line), (what ever you want to write here)
    lcdout $fe, address (second line), (what ever you want to write here)
    This might lead to something good and it might not, but it is something worth your while to try. I tried this with the 20x4 HANTRONIX and I got my screen to do what I wanted it to do.
    boboco's Avatar
    boboco Guest
    Default lcd control
    Hi Rhatidbwoy,
    I've tried all sorts of delay times beween lines, nothing works. I've ordered a new display, as I suppose this one to be defect. Thanks anyway.
    Greetings
    Talking Just for fun ...
    Hi, Boboco
    Was it a 50% Discount ???
    Seriously, you should ask a question about that on the Displaytech site ...
    boboco, As Rhatidbwoy mentioned I have found in the past (8+ years) that most LCD displays require anywhere from 5 to 15 Milliseconds to execute a clear command "$FE,01" or a home command "$FE,02". I have found this to be true with displays from OPTREX,ITRON,and CRYSTALFONTZ. They are all compatable with HD44780 type lcd controllers found on most lcds. Also whenever I use a command to place the cursor to a different location on the lcd I always use "PAUSEUS 100" as I have found in the past some displays require this delay. I have had no problems with any LCD or VFD displays using delays in my software as I have mentioned. LOL
    Italy
    Initialization of a 16x2 LCD.
    (4 bit Interface).
    The first picture is the initialization of a Hitachi HD44780.
    The second picture is the initialization of a Samsung KS0077.
    Best regards,
    Luciano
    Hitachi HD44780 initialization
    (The above picture)
    E=1  D7=0  D6=0  D5=1  D4=1
    E=1  D7=0  D6=0  D5=1  D4=0
    E=1  D7=1  D6=0  D5=0  D4=0
    E=1  D7=0  D6=0  D5=0  D4=0
    E=1  D7=1  D6=1  D5=1  D4=0
    E=1  D7=0  D6=1  D5=1  D4=0
    E=1  D7=1  D6=1  D5=0  D4=0
    Samsung KS0077 initialization
    (The above picture)
    E=1  D7=0  D6=1  D5=0  D4=0
    E=1  D7=1  D6=0  D5=0  D4=1
    boboco's Avatar
    boboco Guest
    Default LCD Control
    Hi all,
    thanks for the help.
    Curious is that the first line functions exactly as it should in every way, only the second line not. If I turn the contrast up to maximal all pixels turn black, though, so at least the line isn't dead.
    I've temporarily replaced the Displaytech with another type of unit. (all that work...., sob!) It worked at once so I take it that the Displaytech is bugged in some way. I've ordered a new one and hope that that will work, otherwise I'll have to change the whole construction to use some other. I'll report when I've got the results.
    Another short question on LCD control +PBP. If I want to control a 4 liner, which is essentially two complete LCDs in one, I've been doing it by switching both enable lines via resistors from one port and shorting each of the enable lines respectively with another two ports to disable it.
    It must be possible to program the PIC so that the selection of two enables is directly possible. (DEFINEs?) I've looked on the board but haven't found anything. Any ideas?
    Greetings
    Rob
    boboco's Avatar
    boboco Guest
    Default LCD Control
    Hi all again,
    sorry Luciano, I didn't mention your post. As it would seem, the KS0077 isn't directly compatable to the HD44780. If that is the case, it would be interesting to write code for it as it is similar. If time allows, I'll try it.
    Greetings,
    Rob
    boboco's Avatar
    boboco Guest
    Default LCD Control
    Hi all,
    Greetings
    Rob
    Italy
    Your display is not correctly initialized.
    (This is why you get only one line).
    In order to use your LCD (KS0070b), you will have
    to manually initialize the KS0070b before you call the
    first PicBasic LCDOUT.
    Below you can find the pseudo code + a table.
    Best regards,
    Luciano
    See PDF page 32 for the initialization of the KS0070B in 4 bit mode
    http://www.ee.oulu.fi/research/tklab...river-3316.pdf
    KS0070b Initialization
    2x16 LCD (KS0070b)
    4 bit mode
    2 lines
    Display=on
    Cursor=off
    Blink=off
    Increment mode
    Entire shif=off
    (Pseude-code, same as the table below).
    Power on
    (PIC and LCD module).
    Wait 40 ms
    (Function Set)
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0010
    Toggle the Enable line:
    PULSOUT Enable_Pin,100 (min.100 µs)
    Set the LCD pins:
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 1000 (2 lines, 5x7 dots)
    Wait 100 µs
    (Display On/Off Control)
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0000
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 1100 (Display on, cursor off, blink off).
    Wait 100 µs
    (Clear display)
    Set the LCD pins:
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0001
    Wait 2 ms
    (Entry Mode Set)
    Set the LCD pins:
    Set the LCD pins:
    DB7,DB6,DB5,DB4 = 0110 (Incremet mode, entire shif off).
    Wait 2 ms
    End of the KS0070b Initialization.
    boboco's Avatar
    boboco Guest
    Thumbs up LCD Control
    Hello Luciano,
    Thanks, Pal. Now it works. And I've learnt something new.
    Best greetings,
    Rob
    Sep 2005
    i two have purchased an lcd that uses a k0007b criver chip i tried you example of initalising the display manualy not notheing hear is my code can some one check it for me please.
    '* Name : LCD template.BAS *
    '* Author : John Hodgkiss *
    '* Notice : Copyright (c) 2007 John Hodgkiss *
    '* : All Rights Reserved *
    '* Date : 17/03/2007 *
    '* Version : 1.0 *
    '* Notes : *
    'Template program for LCD useing a K0007b driver chip
    'KS0070b Initialization
    '2x16 LCD (KS0070b)
    '4 bit mode
    '2 lines
    'Display=on
    'Cursor=off
    'Blink=off
    'Increment mode
    'Entire shif=off
    start:
    'Power on
    'set variables
    output portA
    Db7 var byte
    Db6 var byte
    Db5 var byte
    Db4 var byte
    RS var byte
    E var byte
    PauseA var byte
    PauseC var byte
    'set constants
    PauseA = 10 ' 100us
    PauseC = 200 ' 2ms
    'define
    DEFINE LCD_DREG PORTA 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA 'LCD register select port
    DEFINE LCD_RSBIT 5 'LCD register select bit
    DEFINE LCD_EREG PORTA 'LCD enable port
    DEFINE LCD_EBIT 4 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    pause 400 'pause for 40ms for lcd to start up
    'set pins
    Db7 = portA.3
    Db6 = portA.2
    Db5 = portA.1
    Db4 = portA.0
    RS = portA.4
    E = PortB.3
    output portA
    Output portB
    portA = low
    PortB = low
    setup:
    DB7 = 0
    DB6 = 0
    DB5 = 1
    DB4 = 0
    'Toggle the Enable line:
    PULSOUT E, 100
    pause PauseA
    E = low
    DB7 = 0
    DB6 = 0
    DB5 = 1
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    'set 2 lines 5x7 dots
    DB7 = 1
    DB6 = 0
    DB5 = 0
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    pause PauseA 'pause 100us
    'turn display On/Off control
    DB7 = 0
    DB6 = 0
    DB5 = 0
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    'Display cursor off, blink off
    DB7 = 1
    DB6 = 1
    DB5 = 1
    DB4 = 1
    PULSOUT E, 100
    pause PauseA
    E = low
    pause 10 ' wait 100us
    'clear display
    DB7 = 0
    DB6 = 0
    DB5 = 1
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    DB7 = 0
    DB6 = 0
    DB5 = 0
    DB4 = 1
    PULSOUT E, 100
    pause PauseA
    E = low
    pause PauseC 'pause 2ms
    'Entry mode
    DB7 = 0
    DB6 = 0
    DB5 = 0
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    DB7 = 0
    DB6 = 1
    DB5 = 1
    DB4 = 0
    PULSOUT E, 100
    pause PauseA
    E = low
    pause pauseC
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    is this correct??
    the dispaly does light up but thats it
    here is a link to the displays pdf file
    http://www.maplin.co.uk/Media/PDFs/N27AZ.pdf
    Sep 2005
    hi there again i have been up all night trying to get this thing working no luck can some one please have a lok at my code or does anyone know where a example piece of code is. please iam desperate
    Smile more info
    not a expert but my problems has always been with using a higher speed osc
    and not reseting lcd_dataus to match the crystal more delay for higher speeds just a thought
    Sep 2005
    hi there iam not sure what you mean can you explane
    Wink try
    when i have a problem with the lcd display
    it has been the fact that i use a 20 osc
    and what works for me is to change line
    define lcd_dataus 50
    to
    define lcd_dataus 200
    it just works for me
    Sep 2005
    hi there thanks for the reply.
    how do you know your lcd is in working order, i have ready that if you just provide power to it you should see black boxes is this true. i tried this and all i get is the backlighting up but no boxes.
    skimask's Avatar
    skimask Guest
    Which compiler are you using? 'cause if that code above is PicBasicPro, you really, really need to get reading the PBP manual and learn it.
    You don't have any Black boxes????
    Or your contrast POT is crap, or you didn't installed it correctly.. or you forgot. ANY character LCD i know, once connected will produce those Black boxes.
    R/W pin is left floating in the air... must be tied to gnd
    Some LCD brand may need to tie unused DB<4:0> to Vss or Vdd... have a look to the datasheet
    Quote Originally Posted by Jhdgkss View Post
    Power to LCD - pin 1 ground, pin 2 is 5 volts positive, pin 3 center lug of contrast pot. these are the primary power leads, pin 4 R/s bit, pin 5 R/w and must be as mister_e said ground etc etc . . . now pin 15 Power for LED backlight, pin 16 LED backlight ground. Just because led backlight is on does not mean lcd is powered.
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. LCD will not start
  5. 4x40 LCD control problem
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 11:43
