Decode RC5 ?
Results 1 to 8 of 8
Thread: Decode RC5 ?
    Apr 2004
    Exclamation RC5 program
    Bruce,
    First of all thanks for the code.
    I tried out your program and I get some data in.
    However depending on the angle I keep getting other values when pressing the same button (distance about 60cm)
    I know there is a toggle bit that changes when pressing the same button twice but this should not affect the 'data' part of the RC5 that is filtered out here.
    I have to say that I run the program with a 10MHz crystal instead of 20MHz as specified in your program.
    Can this be the cause?
    Thank you.
    Best regards
    Sep 2003
    INDIA
    Default Small Problem
    Hello Bruce,
    Tried your program on a 16F72 MCU and it works. I get some consistant data on Keypress but it does not tally with the key I pressed. I have a very similar code in PICBASIC PLUS (PROTON) and it works OK.
    Just wanted to ask you:
    1. How do I remove the address code from the data
    2. A couple of keys don't get registered , any idea. Namely #7
    Once again thank you for your help.
    regards
    Charudatt
  1. RC5 code for infrared receiver
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 11th January 2017, 12:34
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  3. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 08:20
  4. IR decode problem "hitachi TV remote"
    Last Post: - 13th March 2006, 15:29
  5. RC5 Encode / Decode
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 18th October 2003, 05:14
