Another interrupt question
Results 1 to 5 of 5
    Sep 2005
    Campbell, CA
    Default Another interrupt question
    I'm trying to get a timer interrupt to work, but the code below just doesn't run.
    Can someone please tell me what I'm doing wrong? It seems like the ISR isn't getting called.
    __________________________________________________ ____________
    DEFINE INTHAND TMRint
    ADCON1 = 7
    RCSTA = $90
    TXSTA = $24
    SPBRG = 25
    wsave VAR BYTE bankA system
    ssave VAR BYTE bankA system
    fsave VAR WORD bankA system '
    ASM_Seconds VAR BYTE bankA
    T0CON = %10000101
    Seconds VAR BYTE
    OldSeconds VAR BYTE
    OldSeconds = 0
    ASM_Seconds = 0
    GoTo START
    Asm
    TMRint
    movwf wsave
    swapf STATUS, W
    clrf STATUS
    movwf ssave
    movf Low FSR0, W
    movwf fsave
    movf High FSR0, W
    movwf fsave+1
    ; Do the real work here
    incf _ASM_Seconds,1
    clrf TMR0IF
    movf fsave, W
    movwf Low FSR0
    movf fsave+1, W
    movwf High FSR0
    swapf ssave, W
    movwf STATUS
    swapf wsave, F
    swapf wsave, W
    retfie
    EndAsm
    START:
    INTCON = %11100000 ' Enable TIMR0 interrupts
    MAINLOOP:
    GoSub GetSecs
    IF Seconds <> OldSeconds THEN
    OldSeconds = Seconds
    HSEROUT [#Seconds," "]
    EnDIF
    GoTo MAINLOOP
    GetSecs:
    INTCON.7 = 0 ' Shut off interrupts when reading register
    Seconds = ASM_Seconds
    INTCON.7 = 1
    Charles Linquist
    Charles Linquis,I never see you setting the TMR0 value which means you are allowing it to overflow every 4.194 seconds. (1/4000000)x4x64x65536). This is assuming your TMR0 is a 16 bit timer.
    Sep 2005
    Campbell, CA
    I realize that I have to jam the timer with a value, I'll calculate that value when I get things running. The problem is - the ISR NEVER seems to get called.
    Charles Linquist
    Hi Charles,
    Change clrf TMR0IF to bcf INTCON,TMR0IF. Everything else looks OK.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Campbell, CA
    That was it!
    Thanks, Bruce.
    Charles Linquist
  1. Interrupt question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 21:12
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. USART interrupt not interrupting right
  5. Interrupt question
    By stone in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 00:11
