Assembly Language + PBP
Results 1 to 3 of 3
    Sep 2005
    Campbell, CA
    Default Assembly Language + PBP
    I have been stumped for the longest time trying to figure out how to transfer variables between PBP and assembly.
    After looking at a bunch of examples, it appears that when I'm in an assembly language routine, all I have to do is put an underscore in front of a PBP variable name and I can transfer the contents of that variable between assembly and PBP.
    Will this always work? Do I have to worry about banks?
    I only use 18F parts.
    Charles Linquist
    Yes. The underscore is all you need, but you can also declare a variable as SYSTEM, and then you don't need the underscore. Just don't get too carried away doing this. All PBP variables need to fit into bank 0 on 14-bit core or bank A on 16-bit core.
    Yes.
    Bad news is, (unless all your variables fit into access RAM) you still need to fiddle with bank switching when using assembler. Good news is, you don't need to worry about program memory page nonsense or bank switching for SRF access with 18F parts.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Wink
    Hi, Charles
    A happy new year for yours.
    Have a look to page 179 of the 3.04 Manual ... written in full letters !!!
  1. Assembly Language inside PBP
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 12th October 2009, 21:52
  2. Replies: 2
    Last Post: - 8th February 2009, 05:10
  3. Assembly Language Conflict
    By NO2K in forum General
    Last Post: - 24th July 2007, 00:42
  4. Passing arrays PBP <-> Assembly
    Last Post: - 16th April 2006, 01:01
  5. Replies: 2
    Last Post: - 8th August 2004, 16:00
