Help with an 16f876a
Results 1 to 5 of 5
    Naslund's Avatar
    Naslund Guest
    Smile Need help
    Hi.
    I’m also trying to go from a 628 to an 876A.
    Could someone give me an example of working pbp2 code that makes
    PortA.0-3 output
    PortB.1-5 output
    PortC.0-3 input
    PortC.4-7 output
    All digital.
    I’m trying to set the TRISX but it won’t work.
    Is it some DEFINE that has to be set?
    I liked the simple 628….
    David
    I’m using
    Pbp 2.42
    PM assembler 4.04
    4Lewis's Avatar
    4Lewis Guest
    Default What changed
    Hello:
    I am having similar problems, what did you change in the code to make it work?
    Hello again, problems are solved, some changes on define sentences and everything is up again
    Anyway thanks for the attention
    Regards.''
  1. Problem with 16F877A but not with 16F876A
    Last Post: - 16th May 2008, 15:18
  2. 16f876a Pwm
    By Hainkm in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 18:33
  3. 16F876A Configuration
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 29th November 2006, 19:30
  4. Pwm 16f876a
    Last Post: - 19th September 2006, 07:35
  5. EPIC Programmer - Works for all chips but the 16F876A
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 13th April 2006, 00:59
