BootLoader with USB to Serial Convertors
Results 1 to 7 of 7
    Hi Mike,
    Since you've already verified this on the same board with the standard serial connection/cable, it could be that the board you're plugging the USB/Serial adapter into is routing some handshaking signals back to the standard DB-9 type serial adapter on the board.
    This may or may not be a good thing depending on the USB/Serial adapter, how it's wired, and what signals it makes available at the DB-9 end.
    I would check this one out first. If you have another PIC dev board with a DB-9 connector that's not wired for looping back signals/handshaking that would tell you.
    This message just means the loader software running on your PC can't communicate with the target PIC. If the boards DB-9 wiring is OK for the adapter, and you're selecting the adapters "virtual" serial port, it should work.
    It could also be sloppy timing or drivers on the converter. I have never had any problems with USB/Serial adapters using the FTDI chipsets, but I have with several other el-cheapo brands. Especially on XP systems.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    forgie's Avatar
    forgie Guest
    Just a thought: see if it's the reset that's causing you grief - AFAIK you can do a hard reset for a few seconds after you click "Program" with the MELabs Loader and it'll all work. So try that, click Program, then straight away do a hard reset (assuming your board has a reset switch). If this works then you know theres a problem with the reset line. If it doesn't work, then I'm fresh out of ideas!
    Bruce sounds like he knows more about the handshaking, but I'll second the fact that FTDI chips work like a charm with all bootloaders (I even use one on my Mac )
    mike101video's Avatar
    mike101video Guest
    Thumbs up
    Thxs all,
    If I press the reset button for about three seconds - it all works. (With two different USB cables.)
    Mike
    forgie's Avatar
    forgie Guest
    Good to hear you got it working. Your USB-Serial adapter must have issues with whatever line is used for the reset signal.
  1. USB Bootloader.
    By HenrikOlsson in forum USB
    Last Post: - 2nd May 2013, 03:46
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  3. Serial data to USB
    By cooksydesign in forum USB
    Last Post: - 29th October 2008, 16:10
  4. USB and serial cable connection(s)
    By ardhuru in forum Schematics
    Last Post: - 18th August 2008, 16:26
  5. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2007, 11:48
