PIC Basic PRO 16F877 USART Interrupt TX
Results 1 to 9 of 9
    Oh Boy. Where to start. I guess from the beginning.
    Since there isn't an OSC definition, I assume you're running at 4Mhz. And, with 4 Mhz, and BRGH (TXSTA.2) set to 0. The error rate for 9600 baud is 7%. That's really high. If you use HSER_TXSTA 24, which sets BRGH to 1, the error rate goes to 0.16%.
    But then you manually set SPBRG to 25, which would be 2400 baud at 4mhz, so the 9600 gets discarded.
    INTCON = %10010000 Along with turning Global interrups on, also enables the External Interrupt INT. But the rest of the program doesn't use INT.
    'PIE1.5 = 1 ' enable interrupt on usart receive
    This line is commented out, so the RX interrupt never gets enabled.
    PIE1.4 = 1 ' enable interrupt on usart transmit
    You cannot use Transmit interrupts with HSEROUT, they are not compatible.
    Just like the compiler would do, I'll stop there and report [too many errors]
    BigH's Avatar
    BigH Guest
    Smile Thanks
    Hi Guys
    Thanks, with your help I think I can now move in the right direction. I am beginning to think I should have stuck to Delphi and Window instead getting involved with these little Beast's . Thanks Again
    Regards Henry
    i heard it often hurt the first time... good luck.
    Don't be afraid, we all had and still have some problems with them sometimes. There's no problem... only learning opportunities
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. USART interrupt not interrupting right
    Last Post: - 6th March 2005, 01:07
  3. pic basic pro (novice user)
    By f6ggy in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2003, 14:29
  4. help pic basic pro
    Last Post: - 29th September 2003, 00:55
  5. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 04:07
