I'm trying to use code I found here to get a reading from a DS1820 device. Whatever I try, this always gives me a 'not present' error. But the brand new 1820 is right there and connected to PORTC.0
I'm using a PIC16F876A for this project.
What am i doing wrong here? The LCD works OK, it's just the reading from the 1820 that won't work, i don't understand why, because it's so simple to connect.Code:DEFINE OSC 4 ' Allocate variables command var byte ' Storage for command i var byte ' Storage for loop counter temp var word ' Storage for temperature DQ var PORTC.0 ' Alias DS1820 data pin DQ_DIR var TRISC.0 ' Alias DS1820 data direction pin Pause 500 ' Wait for LCD to start Lcdout $fe, 1, "Temp in degrees C" ' Display sign-on message ' Mainloop to read the temperature and display on LCD mainloop: Gosub init1820 ' Init the DS1820 command = $cc ' Issue Skip ROM command Gosub write1820 command = $44 ' Start temperature conversion Gosub write1820 Pause 2000 ' Wait 2 seconds for conversion to complete Gosub init1820 ' Do another init command = $cc ' Issue Skip ROM command Gosub write1820 command = $be ' Read the temperature Gosub write1820 Gosub read1820 ' Display the decimal temperature Lcdout $fe, 1, dec (temp >> 1), ".", dec (temp.0 * 5), " degrees C" Goto mainloop ' Do it forever ' Initialize DS1820 and check for presence init1820: Low DQ ' Set the data pin low to init Pauseus 500 ' Wait > 480us DQ_DIR = 1 ' Release data pin (set to input for high) Pauseus 100 ' Wait > 60us If DQ = 1 Then Lcdout $fe, 1, "DS1820 not present" Pause 500 Goto mainloop ' Try again Endif Pauseus 400 ' Wait for end of presence pulse Return ' Write "command" byte to the DS1820 write1820: For i = 1 to 8 ' 8 bits to a byte If command.0 = 0 Then Gosub write0 ' Write a 0 bit Else Gosub write1 ' Write a 1 bit Endif command = command >> 1 ' Shift to next bit Next i Return ' Write a 0 bit to the DS1820 write0: Low DQ Pauseus 60 ' Low for > 60us for 0 DQ_DIR = 1 ' Release data pin (set to input for high) Return ' Write a 1 bit to the DS1820 write1: Low DQ ' Low for < 15us for 1 @ nop ' Delay 1us at 4MHz DQ_DIR = 1 ' Release data pin (set to input for high) Pauseus 60 ' Use up rest of time slot Return ' Read temperature from the DS1820 read1820: For i = 1 to 16 ' 16 bits to a word temp = temp >> 1 ' Shift down bits Gosub readbit ' Get the bit to the top of temp Next i Return ' Read a bit from the DS1820 readbit: temp.15 = 1 ' Preset read bit to 1 Low DQ ' Start the time slot @ nop ' Delay 1us at 4MHz DQ_DIR = 1 ' Release data pin (set to input for high) If DQ = 0 Then temp.15 = 0 ' Set bit to 0 Endif Pauseus 60 ' Wait out rest of time slot Return End
Thanks in advance,
