i'm trying to put different text's on the lcd (8 char's long)
with a for next loop from 1 to 3
if the counter is 1 the display should say "one1one1"
wait 500 ms , clear screen
if the counter is 2 the display should say "twotwo22"
wait 500 ms, clear screen
if the counter is 3 the display should say "three333"
then goto start
i'm trying to put the text in a array and finding it back with lookup but
whatever i try it doesn't do it like it should
the goal is to put all text in one block, so i can change it easy, because i
need the different text on different places in my program,
and keeps my main routine short!
I've searched thru the entire board, but can't find somthing like it
this is only the test program, but it keeps me puzzled all day
pic 16F876 and 2*16 lcd module
INCLUDE "bs1defs.bas"
define osc 8
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 5
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
DEFINE ADC_BITS 8
tel var word
waarde var BYTE
waarde2 var word
text var BYTE
counter var word
counter1 var word
stap var word
start:
stap=0
lcdout $fe,1 'cls
pause 10
for counter = 1 to 3
gosub numbers
PAUSE 100
lcdout $FE,1,str waarde\8
lcdout $fe,1 'cls
next counter
goto start
numbers:
for counter1 =STAP to STAP+7
lookup counter1,["one1one1twotwo22three333"],text
waarde(counter1)=text
next counter1
stap=stap+8
if stap>24 then
stap=0
