How do RCIF works?
Results 1 to 10 of 10
    Yes, it looks like it is the ICD.
    If I program it, it is working, so that make it a bit difficult if I want to debug a large project which are using HSERIN?
    THX
    yeeehaaa! O.K so you can probably put some DISABLE DEBUG and ENABLE DEBUG in few place in your program OR use another structure in.
    I mean, send some question or ideas with HSEROUT, then sit for an answer.
    Just a thought... i'm not a big fan and user of any ICD. In fact, i can't remind when i used it for the last time... Sorry!
    I'm sure somebody else will come up here with a better solution than mine anyways.
    Good luck!
    Thx Steve!!
    Another thought. You can even use the serial communicator (no ICD) and use an USART interrupt routine that will do something you ask.
    Let's make things more clear by using an example.
    Let's say i want to change a,b,c parameter while the program is running. With serial communicator i'll send a specific start character, then the parameter i want to change. let's say UUCHANGEA#120
    in the interrupt routine i'll write something like
    HSERIN [WAIT("CHANGE"),VarToBeChange,ValueToBeChange)
    Select case VarToBeChange
        CASE "A" : a=ValueToBeChange
        CASE "B" : b=ValueToBeChange
        CASE "C" : c=ValueToBeChange
        END SELECT
    By sending UUCHANGEA#120 , the a Variable is suppose to be equal to 120. Read the Serial Communicator help on that (under Transmit windows>> Parse control character) Really handy sometimes.
    But be aware of the latency of your whole program... maybe a bigger amount of UU "Header" will be usefull. OR simply send something then wait fow the PIC question... as you wish.
    HTH
    Hi Steve.
    The # sign in the sending message isn't it read by the ValueToBeChange variable?
    Quote Originally Posted by mister_e
        END SELECT
    NOPE, it's a MCS feature. Look in the help file. The parse control character must be enable in the MCS serial communicator.
  1. PORTA.0 works, PORTB.7 or .6 do not
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2009, 05:25
  2. Replies: 42
    Last Post: - 14th January 2008, 12:38
  3. TMR1 How it works?
    Last Post: - 12th January 2007, 15:24
  4. EPIC Programmer - Works for all chips but the 16F876A
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 13th April 2006, 00:59
  5. 16F628A using PORTA.4, and it works, but...
    By zx81 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 09:45
