How do RCIF works?
Results 1 to 10 of 10
    Default How do RCIF works?
    This is strange, I'm using Microcode studio plus ICD.
    And while the code is running I use the "ICD Serial In" to send a character to the PIC, but my RCIF=0 so it never goes into my label?
    Here is the part of my code?
    <hr>
    DEFINE LOADER_USED 1 ' bootloader
    DEFINE HSER_RCSTA 90h ' enable serial port,
    define HSER_TXSTA 24h ' enable transmit,
    DEFINE HSER_BAUD 9600 ' set baudrate to 9600
    DEFINE HSER_CLOERR 1 ' automatic clear overrun error
    RCIF VAR PIR1.5 ' Receive interrupt flag (1=full , 0=empty)
    TXIF VAR PIR1.4 ' Transmit interrupt flag (1=empty, 0=full)
    if RCIF then ' incomming data?
    gosub MonitorSerialDataReceived
    <hr>
    mmm, could be many things, can you post your whole code?
    One pointer, if you don't use any HSERIN/HSEROUT in your code, the compiler will never consider your SPBRG, TXSTA, RCSTA define. In this case you should write directly to them. Same thing with The TRISx. HSERIN/HSEROUT will do the job for you, but if you don't use them... maybe you'll receive character but... maybe you'll never saw them at the output... maybe.
    Another Thing...
    Quote Originally Posted by Koosa's code
    should be
    DEFINE HSER_CLROERR 1 ' automatic clear overrun error
    The define's spelling is verrrrrrrrrrrrrrrryyy important. In uppercase tooo.
    Maybe the following may help you.
    http://www.picbasic.co.uk/forum/show...42&postcount=2
    http://www.picbasic.co.uk/forum/show...1&postcount=11
    Hi Steve
    Thank you verymuch for your feedback, here is my code?
    <pre>
    ' enable continuous receive
    ' BRGH=1
    define HSER_SPBRG 103 ' set baudrate to 2400
    SerialData var byte
    SWITCHPIN VAR PORTD.1
    BUZZER Var PORTC.2
    TRISC = %10000000 ' PORTC.7 is the RX input, PORTC.6 is the TX output
    pause 10 'safe start-up delay
    high SWITCHPIN
    high buzzer
    low buzzer
    hserin [Serialdata] ' take it
    hserout ["x=",serialdata] ' send it
    </pre>
    mmm, so is it working or not?
    Assuming it's not working. Can you just forget the ICD idea and use compile-program button (NOT ICD). Then use the SerialCommunicator of MCS (F4)?
    About now?
    If not, what about if you change your main label just before the IF RCIF... line?
    must be
    AND OOPS i just saw it's my mistake too on the link i gave.. mmm. BTW it was tested at that time... so i bet on the ICD thing. Keep us inform.
    PS are you using the MAX232 circuit provide in the MCS help?
    Yes, it looks like it is the ICD.
    If I program it, it is working, so that make it a bit difficult if I want to debug a large project which are using HSERIN?
    THX
    yeeehaaa! O.K so you can probably put some DISABLE DEBUG and ENABLE DEBUG in few place in your program OR use another structure in.
    I mean, send some question or ideas with HSEROUT, then sit for an answer.
    Just a thought... i'm not a big fan and user of any ICD. In fact, i can't remind when i used it for the last time... Sorry!
    I'm sure somebody else will come up here with a better solution than mine anyways.
    Good luck!
  1. PORTA.0 works, PORTB.7 or .6 do not
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2009, 04:25
  2. Replies: 42
    Last Post: - 14th January 2008, 11:38
  3. TMR1 How it works?
    Last Post: - 12th January 2007, 14:24
  4. EPIC Programmer - Works for all chips but the 16F876A
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 23:59
  5. 16F628A using PORTA.4, and it works, but...
    By zx81 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 08:45
