110 Baud Serial Communications - Possible?
Results 1 to 2 of 2
    Aug 2005
    Default 110 Baud Serial Communications - Possible?
    Im looking at using PIC's for a serial interface / converter for some legacy equipment, which requires a baud rate of 110bps.
    Is there any way a pic can go down to 110bps for serial input and output?
    All i have found so far is some info on 300.
    Sep 2005
    Campbell, CA
    You should be able to do this easily.
    The method depends on whether or not you are using software (SERIN2/SEROUT2) or hardware (HSERIN/HSEROUT) UARTS.
    For SERIN2/SEROUT2 you can use the formula given on page 129 of the PBP manual -
    MODE = (1000000/baud) - 20
    For HSERIN/HSEROUT check the datasheet for your processor. You will have to directly set BRGH and SPBRG according to your oscillator frequency.
    Charles Linquist
    Last Post: - 8th March 2010, 21:58
  2. Serial reading of binary at 75 baud
    By JasonMarsh in forum Serial
    Last Post: - 20th February 2008, 17:36
  3. Can PicBasic support 56700 serial baud?
    By dw_picbasic in forum mel PIC BASIC
    Last Post: - 5th February 2007, 02:42
  4. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
