Hard disk motor - DC or stepper?
Results 1 to 18 of 18
Threaded View
  1. #14
    Italy
    Brushless, sensorless motors with three connections are in
    fact, not DC motors at all. They are actually permanent
    magnet synchronous AC, 3-phase motors.
    The commutation is done electronically. Three distinct
    semi sinusoidal waveforms (not pure sinewave AC) that come in
    at different times (or degrees) will causes the rotor to
    rotate with the changing (alternating) magnetic fields of
    the stator.
    See page 7 of this PDF:
    ("some sort of 'fixed' sequence to send to the motor")
    AN INTRODUCTION TO SENSORLESS BRUSHLESS DC MOTOR
    DRIVE APPLICATIONS WITH THE ST72141
    http://www.st.com/stonline/books/pdf/docs/7209.pdf
    Read the documents below to understand the problem.
    AVR444: Sensorless control of 3-phase brushless DC motors
    http://www.atmel.com/dyn/resources/p...ts/doc8012.pdf
    ATAVRMC100
    http://www.atmel.com/dyn/resources/p...ts/doc7551.pdf
    The ATAVRMC100 is an evaluation kit dedicated to brushless DC motor control, for
    both Hall effect sensor control and sensorless control using Back ElectroMotive Force.
    The kit includes an evaluation board, a 3-phase BLDC motor and a demonstration software.
    It allows users to quickly evaluate the capability of the AVR® microcontroller
    AT90PWM3 to control high speed brushless DC motor applications.
    The kit can also serve as a development platform. Low cost AVR development tools
    make debugging easier, and source codes, written in C, can be easily re-used by developers
    for their own motor control applications.
    Why do you need this motor?
    What is the final application for this motor?
    Best regards,
    Luciano
  1. 18f4431; driving a stepper IN HARDWARE mode
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 21st January 2010, 17:49
  2. Replies: 11
    Last Post: - 6th November 2008, 11:27
  3. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 11:21
  4. problem with stepper!!
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 17:41
  5. hard disk and PBP
    By ely in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 03:16
