Does the motor have 3 wires or 4 wires? (You say 3 terminals in your first post).
Are the wires coloured?
I the wires are not coloured, put a label on each wire with A,B,C.
What is the resistance in ohm between the wires?
Example:
The 3 wires are RED, GREEN, BACK.
Between RED and GREEN I have 10 ohm.
Between RED and BACK I have 20 ohm.
Between GREEN and BACK I have 10 ohm.
The RED wire is insulated from the metal case of the motor.
The GREEN wire is insulated from the metal case of the motor.
The BACK wire is insulated from the metal case of the motor.
Can you post pictures where we can see the the drive and
a close-up of the motor and wires?
Best regards,
Luciano
