explanation about serout2 and serin2
Results 1 to 2 of 2
    micro's Avatar
    micro Guest
    Default explanation about serout2 and serin2
    i want to know what does Flow pin mean?
    SERIN2 DataPin{\FlowPin},Mode,{ParityLabel,} {Timeout,Label,}[Item...]
    in this command i think flow pin in a test pin to out the recieved bits
    to return it to transmitter pin at flow pin ??? is that right ???
    SEROUT2 DataPin{\FlowPin},Mode,{Pace,} {Timeout,Label,}[Item...]
    in this command flow pin recieves bit from the reciever datapin to test it if there is an error or not, is that right ?
    This option is for "flow control". It signals the sending unit to stop or send inbound data. It's used to keep inbound data from over flowing, and allows the receiving PIC time to perform houskeeping or move received data.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  2. SERIN2 – SEROUT2 and Manchester mistake.
    By RCtech in forum Serial
    Last Post: - 4th September 2007, 23:55
  3. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 10:03
  4. Simple PC Menu System with Serin2
    Last Post: - 3rd April 2005, 09:27
  5. Serin2 and Serout2 with or without level converter
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 31st May 2004, 08:10
