PWM on PIC16F88
Results 1 to 37 of 37
Thread: PWM on PIC16F88
    $+1 mean 'from here to the next instruction' this avoid to use labels. The GOTO $+1 just jump to the next instruction. a single goto use 2 instruction cycle.
    $-1 jump to the previous instruction.
    You can also change the 1 to whatever else amount of line... but this could make your code harder to read.
    <hr>
    i'll look at that later today for the other code.
    Hey! you're such a lucky guy to have ASM support on a PICBASIC forum.
    play with this one
            ;       Simple program which display ADC results of AN0
            ;       to 8 LED connected to PORTB<7:0>
            ;       Enjoy!
            ;       Steve AKA Mister_e
            list p=16f88, W=-302
                            ; bank switching
            INCLUDE "p16f88.inc"
            ;       Program Configuration Register 1
    CFG1 = _INTRC_IO & _MCLR_OFF & _BODEN_ON & _PWRTE_ON & _WDT_OFF & _LVP_OFF
    CFG2 = _DEBUG_OFF & _CP_OFF & _CCP1_RB0 & _WRT_PROTECT_OFF & _CPD_OFF
            __CONFIG    _CONFIG1,  CFG1 & CFG2
            ;       Program Configuration Register 2
            __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
            ORG 0
            BANKSEL OSCCON
            MOVLW   B'01100000'
            MOVWF   OSCCON          ; 4 MHz INT CLOCK MODE
            BTFSS   OSCCON,IOFS     ; wait 'till int osc is stable
            GOTO    $-1
            BANKSEL TRISA
            MOVLW   .1
            MOVWF   TRISA           ; porta.0 as input, other to output
            CLRF    TRISB           ; all pins set to output
            MOVLW   .7
            MOVWF   CMCON           ; disable analog comparator
                    ;       ADC setup
            BANKSEL ANSEL
            MOVLW   .1
            MOVWF   ANSEL           ; Disable all ADCs but AN0
            CLRF    ADCON1          ; Left justified results
                                    ; ADCS2 : disabled
                                    ; Vref : Vdd, Vss
            BANKSEL ADCON0
            MOVLW   B'01000001'
            MOVWF   ADCON0          ; ADCS : Fosc/8
                                    ; select AN0
                                    ; ADON = 1
                    ;       Hardware initialisation
            CLRF    PORTB           ; Clear all
            CLRF    PORTA           ; outputs
            ;       Program Start
    Start
                    ;       ADC Conversion
            MOVLW   .12             ; ~12 uSec acquisition loop
            DECFSZ  W,F             ;
            GOTO    $-1             ;
            BSF     ADCON0, GO_DONE ; Start conversion
            BTFSC   ADCON0, GO_DONE ; conversion finished?
            GOTO    $-1             ;   NO, wait again
                    ;       Display result
            MOVF    ADRESH,W        ; Move ADC result to Wreg
            MOVWF   PORTB           ; display it on PORTB
            GOTO    Start
    Nov 2007
    Talking thanks alot.
    hi ya am surely one lucky guy.i know i might me asking for alot but can u please send the schematic for the adc code. by the way am called gonza, am from uganda in eastafrica.its like am one of the very few people in my part of the world dealing with microcontrollers.its really cool stuff i must say...... thanks alot for the support i appreciate it.
    There's no real difficulties here, LED cathode goes to GND, anode goes to a resistor (200-300 ohm) lead, and the other resistor lead goes to the PIC PORTB pins. repeat it 8 times.
    pot ( <10K ) wiper goes to the AN0 pin (PORTA.0), one pot side on gnd, the other to Vdd.
    Not much!
    Nov 2007
    Default thanks
    okay mate am going to try that.
    Nov 2007
    Talking the adc code works
    hey the code works very well. thank you. pliease help me with sample code for reading and writing to the eeprom.plays with leds. thanks
    Don't push your luck too much you should have some code example in the datasheet?
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  4. Replies: 8
    Last Post: - 7th December 2006, 15:42
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
