Hi.
How do you write your instant interrupts? When the desired code for the interrupt is too complex to write in ASM, I've to write in Basic. But I dont like the software /pseudo/ interrupts.
Hi.
Bulman, First you need to locate the instant interrupt routines written by Tim Box and then place these lines before any other lines in your code:
INCLUDE "INT_CTRL-18F.inc" ' Interrupt Control routines
DEFINE TMR1_FREQ 100
DEFINE TMR1_HANDLER _TIMR1
Then before your main code segment, insert the interrupt routine's. Here is an example of a simple one using a 100 Hz. interrupt to set some pacing counters.
'INTERRUPT SERVICE ROUTINE FOR TIMER 1
TIMR1:
LOOPCNTR = LOOPCNTR + 1 'INCREMENT LOOP COUNTER
TIMSTAMP = TIMSTAMP + 1 'INCREMENT VARIABLE
VOTIME = VOTIME + 1 'INCREMENT VARIABLE
LEDTIMR = LEDTIMR + 1
IF LEDTIMR >= 10 THEN
TOGGLE WATCH_DOG 'KEEP WATCHDOG HAPPY
LEDTIMR = 0
After the interrupt routine is complete you mearly "Return" to the program. It's that simple. All if the information is in the "Instant Interrupt Routine" documentation.
I can't remember where I found the "Instant Interrupt Routine" include file but if you do a search of the web I'm sure you will find it. LOL
