cassette tape motor speed control
Results 1 to 7 of 7
    KB3BYT's Avatar
    KB3BYT Guest
    Question cassette tape motor speed control
    I'd like to make a standard off the shelf five dollar cassette tape player slow down to half or quarter speed.
    A tape player has a 1.7 volt two wire DC motor.
    It seems that feeding it 1.2 volts will run slower but no more push..so it stalls.
    I was wondering if I can pulse the full 1.7 volts real fast.....maybe at a few Hz.... so the motor has enough volts to push the drive belt but missing a beat here and there to make it move slower rpms.
    We had a teriffic discussion on the old list about using pulses to slow down AC
    motors with solid state relays to make the rollers go slower in laminators
    we were doing heat applications of printed circuit boards and laser printer schematics.
    I was wondering if that same logic could be applied to make a cassette tape motor run slower...but still have enough strength to push the tape.
    The end use would be to tape morse code on the radio and then play it back slower for the new guys who don't understand fast morse code yet.
    Any advice about what pulse rate I should target the circuitry around?
    Rob KB3BYT
    Feb 2003
    Will the motor stand a HIGHER voltage ?
    If so, make it run fast for the recording then playback at normal speed which will give the same result.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Seems like a very archaic way of doing things...
    Since a PIC can send perfect morse at whatever speed you want electronically, you can simply fill-up an EEPROM with ASCII data downloaded from a PC serially (or have the PIC generate random characters), set the speed you want and away it goes... and no moving parts other than a loudspeaker cone!
    KB3BYT's Avatar
    KB3BYT Guest
    Default The task is to be able to record any transmissions and then replay slower.
    This idea is that we have new radio operators that listen to the high speed morse on the radio and its just too fast for them so if we give them the opportunity to capture it and replay it ...maybe slower...then they get to have
    a real world sense of whats going on instead of being locked into only listening to code practice.... computer generated or PIC generated.. or tapes.
    So I figured that the basic $5 players available everywhere were perfect to
    chop up and get at the motor speed control.
    They don't have record heads....the $5 units only do playback..... so
    I don't wnat to figure out how to ruin a tape recorder... they cost more...
    I just want to make a player get the speed dropped for playback.
    So back to the task at hand......
    what frequency would be the right frequency to pulse a DC motor so that it
    slowed the motor but didn't make it stall?
    And is it OK to do that with a PIC12C509 or PIC16F84 or PIC16F628...etc..
    with minimal part list. I'm thinking of making two buttons control pulse rate
    UP and DOWN and one output pin running the 1.7 volt DC motor.
    We would not even care if the pulsing made for a grainy playback.
    It would still be slow morse code and the dits and dahs would be understandable.
    Those cheap motors have a working torque curve disproportionate to their supply voltage... best thing is to spend $5 and try it... but also consider...
    1. You halve the playback speed, you halve the TONE... nice 400Hz Morse doesn't sound too good when played back say at 100Hz quarter speed.
    2. Small DC motors running at below their optimal speed will run HOT.
    Coincidentally, there I was going through a little Hamlet in deep green leafy England the other day and stopped to browse an Antiquariat that caught my eye (as if you didn't already know, girls live to shop)... There in a dusty corner was an original and boxed 12" vynil Record (you know the kind of thing people bought for entertainment before they invented CD's) - original 1960's "Teach Yourself Morse Code". As you got more proficient, you dialled up the speed on your record deck from 16rpm to 78rpm. Hands up anyone who's got a Record Deck with that speed range nowadays!
    KB3BYT's Avatar
    KB3BYT Guest
    Default halve tone
    Yes I agree that halving tone will make for some raspy CW but its not the tone
    thats important in this project...its the ability to give the novices a shot at
    nearly real time decoding what they hear go by at blistering speeds.
    I may do this with a 555 instead of a PIC.
    I will post all results of this experiment...good or bad.
    My brand new TEAC retro console mimic has 33 44 and 78. I was playing 78s last week. They truly do suck.
    I've been listening to http://www.shoutcast.com and digitising into mp3 for so long now that I forgot just how bad
    radio and vinyl sounds. I carry a gumstick size 512 mb music toy that holds 100 tunes on it when I take a bus.
    Oh ...and yes..... I am familiar with the various old code teaching methods with records and also paper tape.
    I actually have an old paper tape contraption that plays CW with 3 inch reels of paper tape.
    Its fun to sit that next to the PIC12C509 mint can code practice toy when showing off the hobby.
    Its shows the range of technology from paper and tubes to SMD.
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 16:40
  2. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 14:26
  3. Allow better control of text in GUI
    By Archangel in forum PBP Wish List
    Last Post: - 19th February 2007, 14:25
  4. Control unlimited servos at the same time
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 15:14
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
