Proton+ and PicBasicpro
Results 1 to 35 of 35
    Mar 2006
    Smile
    Quote Originally Posted by picnaut View Post
    Well, first of all Steve, in answer to your question (which kind of sounds like my 13 year old is asking it), I actually come in here to help people, and rarely to "start" a conversation about PDS versus PBP. If you hadn't noticed, I didn't start this thread. Besides, your question is kind of silly. You have more posts on the PDS forum than I have on this forum so, "if you're so totally in love with PBP...", well, you get my point.
    Anyway, I browse the PBP forum and see if there's something general that I can help people with (i.e. hardware, logic flow). For instance, I noticed that someone wanted a program that would back up code automatically. So, I wrote a piece of software that works with PBP and PDS. I did that to help other PIC programmers. But, maybe, I shouldn't bother contributing on this forum any more.
    In any case, I didn't join this thread to start trouble, just to provide a little balance. And, as for your "Proton beta tester" contributions, I've heard both sides of the story regarding this and, personally, I wouldn't rate you too highly as a Proton authority. Something tells me your DJ skills are probably suspect too.
    Have a nice day.
    Sir:
    Have you tried Porting PDS "SD file system" fom Proton to PBP? I am in need of help using MMC and SD as a scoreboard logger and directly output as excel file
    Yours Trully,
    Ryan
    Red face
    Uh. You've picked a strange thread to place your post on, and an even stranger choice of member. I don't use PBP anymore.
    However, I'm sure that there are some members here who oculd help.
    Post your question in the "mel PIC BASIC Pro" section maybe.
    Cheers.
    ---> picnaut
    Mar 2006
    Unhappy
    Cheers.
    Too bad!!!
    Mar 2006
    INDIA
    I have made several Industrial project on PBP, i using PBP since 1999, All my prjects are running with great stability. I have also purchased ( Second hand PDS with usbdongle) only for 32 bit ( LONG ) variable. but stability not seen ( Strange Wrong behavior in industrial environment in my NC Milling machine. ).
    But. Now PBP have 32 bit var. & I think mister_e's keypad routine and Darrel Taylor 's LCD BARgraphs, Instant Interrupts and enypin routine makes it easy and more powerfull.
  1. Usb Mass Storage With 18f4550
    By wagner in forum USB
    Last Post: - 17th August 2008, 16:46
  2. Proton PICBASIC vs MeLabs PICBASIC
    By Fredrick in forum General
    Last Post: - 11th January 2008, 21:51
