Proton+ and PicBasicpro
Results 1 to 35 of 35
    Um, that made me chuckle.
    ---> picnaut
    badrad's Avatar
    badrad Guest
    I heard the "Master" Beta Tester group only test their personal code privately, but may resort to applying various forms of mechanical stimulus to generate specific test outcomes...
    lab310's Avatar
    lab310 Guest
    I've been a PBP user some years now, and it served me well. But, as my projects start to become more & more complicated, I've begun to realize that PBP's capabilities won't be enough for my work. Missing math, string , arrays... are starting to be main problem in all of my new projects, and it is more noticeable now when I switched from 16F to 18F series. After investigating, I found only 3 valuable "players" on market: PBP, Proton+ and MicroBasic. A plain and simple truth is that PBP is less capable compiler of those 3. MicroBasic proved to be good compiler, bat buggy and it has more C than basic like syntax (and I REALLY HATE C). But Proton+ was a revelation to me: it has almost same syntax as PBP and it is loaded with features. Also it is as solid as PBP (i.e. rock solid).So far I didn't try PDS but only older version of standalone compiler, but probably will buy PDS in near future.
    My advice to you is: If you are a begginer, go with Microbasic (if you are on the budget) or Proton PDS. With both of them you got more capabilities, but also something even more valuable: the product that is developing, and for witch you can get a new features (for free also).
    If you already have some valuable project in PBP, stick with it as long as you can, although limited it is a stable and good compiler, and you will save some money buy not bying another compiler.
    Hangover, Germany
    Wink
    Oh,
    it's crazy, that this threat isn't stopped long ago...
    I have the same question, but in this forum you should not ask such questions and the PDS-Forum doesn't work and nobody is interested to get him to work (I can't register).
    I've looked at PDS for local variables or function-declaration, subroutines with parameters etc.... but I don't find it!
    The demo doesn't support my PICs here and ...
    So I'm working furtherone with PBP and write all the missing things by my own hands ;-) But I think greater projects (>16F876, 18F252) were done better with PDS.
  1. Usb Mass Storage With 18f4550
    By wagner in forum USB
    Last Post: - 17th August 2008, 17:46
  2. Proton PICBASIC vs MeLabs PICBASIC
    By Fredrick in forum General
    Last Post: - 11th January 2008, 22:51
