Hopefully someone has some suggestions for me on this one.
I need to write a program to be able to count pulses that run from around 0.25Hz to 4Hz. The PULSEIN command would likely time-out long before it reads any pulses. I think I will need to use tmr1 or similar and advance a counter at each roll-over of the timer, and then convert this value to a time between my external pulses. Then, with some simple math, I can figure out the frequency.
My biggest problem is being able to setup the timer to run properly. I'm not sure how to do this. And, should I set-up my external pulse as an interrupt? I will likely be using a PIC16F627 as I have a couple of these handy.
Any help would be much appreciated.
Nick
