Unusual serial comunication
Results 1 to 8 of 8
    Oct 2003
    holland
    Then put a big capacitor in the neighborhood of the BC547. The collector resistor of the bc547 must be at the stable site of the supply.
    The 2x100 ohm resistors for the data switch might be higher in value if the supply current of the PIC1 is low.
    You have to play with it, because I don't know what you are making. It was yust an example of an idea.
    Jun 2004
    Default Finally it works !
    Thank you , it is working finally, I put 26ohm resistors instead of 100ohm.
    The pics are communicating to each other, but the main slave device, don't.
    It doe not have enough power ! The slave device is powered by the master device with 5v and it drains about 500mA. Pic1 inside the slave device is satisfied with 3v but the main device don't ... hmmmm .... what can I do in this situation ?
    Oct 2003
    holland
    The main pic gets alway's 5 volt or did you make an other circuit than I drew?
    Or your 7805 is broken. or your main supply is not strong enough.
    Or did you build sommething else. if so please let me see the drawing then.
    Jun 2004
    hm .. can I talk with you ? Can you give me a messenger address where I can explain you everyting more detailed ? thank you
    Oct 2003
    holland
    I don't have a messenger adres. Only an email adres.
  1. Replies: 33
    Last Post: - 19th March 2010, 04:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  5. Replies: 2
    Last Post: - 23rd July 2006, 09:16
